Drive shaft couplers - stock, poly or ?
#41
FYI, I recently tried to buy a Protahne Six-Shooter coupler to inspect it and see if I wanted to use it instead to the DSS poly coupler and was informed by the vendor that they have stopped selling the Six-Shooter while the manufacturer redesigns it before resuming production. Apparently, they recognize there is an issue with the current design.
#42
Just replaced mine with billet out back and DSS poly out front, glad I did as my couplers were toast, I woulda been surprised if it could have taken one more hard launch. Zero vibrations.
#43
#44
Im upgrading my factory 6061 driveshaft w rpm 10 mm couplers...I have auto and 8 sec potential...should b jus fine
#45
How did you like that setup? I have two aluminums in and it starts to vibrate after 10mins of driving. I'm assuming it expands causing vibrations. I plan on doing dss up front amd leave the back aluminum.
