Hi everybody, so let me start by saying I have been building this for a little while and am hopefully gonna be done this week. But here is a list of my parts and I was wondering what you guys thought this combo would make:
Stock ls1 bottom
317 heads
Ls9 cam (proper springs and ls7 lifters)
Bbk ssi intake
Bbk shorties
2.5 x pipe no cats
Borla bullet exhaust
A&a supercharger d1sc with 3.6 pulley
60lb injectors
E85
Any guesses, not really looking to be told stuff will break I figure it will run until it won't. Just all around thoughts on power
Reason: Forgot engine spec
My thoughts on why I have a stock fuel pump is, with a 40 amp boost a pump, which I know lots of people with similar set ups and the 20 amp make more than 550 at 8 lbs of boost. I had thought about a better pump however ls1 cars flow at 58psi out of the box and the boost a pump should keep it pretty consistent, with 60lb injectors which are rated at 43.5 psi with 58psi the should push 69.2 at 80% duty cycle. I am not too concerned with fuel starving at this point I might change my mind in the future, I know fuel pumps are cheap I think I will be good and in the low 600's. I could be wrong heck it might not even start and I will be at 0. Thank you for your thoughts
Here's a quick update after a misserable time at the tuners I had 3 injectors go static and bought some 80 lbs ones from him. My knock sensors gasket decided to stop gasketing, if that's a word and sprayed oil everywhere. So we tuned as best we could, I will Dyno tune it there in a few weeks as long as more stuff doesn't break. I think I am going to add a 255 walboro also just because it makes sense.
Later that night I replaced the seal in Valley and on the knock sensors. So I decided y not try and drive it it's a got a decent tune, and now it actually feels slower. That makes zero sense it runs great it just doesn't launch at all and I back off before it get too lean. Anyone else have this problem with launching?
may just be low timing should do better after finial tune how much power did it make with all the problems? or did you even get a good pull
