Installation Charges
Apr 25, 2014 | 12:19 PM
Is $2400 a reasonable price to pay for a Procharger Stage II install in Northern CA for a 99 C5 Coupe?
Apr 25, 2014 | 01:51 PM
What is included in the charge? Larger injectors, dyno tuning, fuel system upgrade, boost and FP gauges? Depending on what is "in the box?, it could be an OK deal.
Apr 25, 2014 | 05:18 PM
This includes installation, tune, and injectors
Apr 25, 2014 | 07:30 PM
i would say not if all you are getting is installation, tune, and injectors. Means they are charging you about 1500 for the install.
Apr 25, 2014 | 08:05 PM
$1750 install
$500 dyno tune
$750 for in tank fuel pump
Must be the Bay Area thing!
Apr 26, 2014 | 03:58 AM
Any recommendation on installers in the Bay Area?
Apr 26, 2014 | 10:15 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Quote:
Originally Posted by
Caveboy
Sounds a little pricey but it could be correct!
Caveboy
Tune should be around $600 that leaves $1800 for install!
Are they going to pin the crank too?
Because that is a labor intensive job and if they are going to install a fuel pump and provide the injectors too then that could very well be a decent amount for the installation!
Caveboy
What part of the Bay Area are you in?
Thanks,Matt
Apr 26, 2014 | 10:20 AM
Apr 26, 2014 | 10:57 AM
The in tank fuel pump install is $750 labor only
Apr 26, 2014 | 11:21 AM
Caveboy
Man if you lived closer I would do it for you! and set you up fuel wise too (like mine
You should also look into getting a Racetronix Hotwire kit for the fuel pump and minimum a KB BAP too!
http://www.racetronix.biz/itemdesc.a...WH-007&eq=&Tp=
After 2003 1/2 year model (or top of fuel tank mounted fuel pump)
http://www.racetronix.biz/itemdesc.a...WH-008&eq=&Tp=
Thanks,Matt
Apr 26, 2014 | 12:02 PM
Price sounds like it could be about right.
Apr 26, 2014 | 01:55 PM
Caveboy
thats about 650 more then it should be for a 99
jack car up, pull wheel off, undone 3 15mm bolts, pull lines of and take out 6 8mm bolts and pull pump
Apr 26, 2014 | 04:12 PM
I thought so too ! Cannot imagine it takes 6 hours to do a fuel pump
Apr 26, 2014 | 04:52 PM
seems high to me considering there are shops on here that run specials of around $6000 installed, the kit itself is $5200ish....
Apr 26, 2014 | 09:59 PM
St. Jude Donor '09
Caveboy
$1750 install
$500 dyno tune
Perfectly reasonable prices.
Apr 26, 2014 | 11:39 PM
Im getting my A&A kit installed with a dyno tune for 1600 on an 04.
Apr 27, 2014 | 11:43 AM
ascastil
Where at?
