Compound Forced Induction
Old Apr 26, 2014 | 04:47 PM
c6silver's Avatar
c6silver
Default Compound Forced Induction
I've been salivating about this since I first read about it in Jeff Hartman's book about Tuning Engine Management Systems, where they put a Camry V6 in place of an MR2's 4 cylinder, put on a TRD (Magnusson) supercharger and THEN put on a big turbo...has anyone ever done a 'Vette like this ? I dream of a big inch stroker with a TVS2300 blower and a BIG rear mounted Borg Warner turbo with a 5 inch exhaust side...talk about a power curve ! Please discuss...
Old Apr 26, 2014 | 07:02 PM
mobius's Avatar
mobius
why bother, you can do more than you need with a single power adder... more complexity and expense for no real gain
Old Apr 26, 2014 | 08:09 PM
danieloneil01's Avatar
danieloneil01
Talk about heat soak. Guy on another forum bought a CTS-V that had a PD and twins. Sold the PD shortly after because it was a waste and made less power than what the twins could do all by themselves.
It's neat but nothing more.
Old Apr 26, 2014 | 08:44 PM
SBCGENII's Avatar
SBCGENII
Works beast with 2 turbos. How much boost are you looking to make 75 100psi?
Old Apr 26, 2014 | 08:53 PM
PhysicsDude55's Avatar
PhysicsDude55
Not really worth it on a streetable big cube engine like an LS engine.
Its more useful on a smaller engine.
Old Apr 26, 2014 | 10:54 PM
LTstewy8's Avatar
LTstewy8
It also works on large diesel generators, but I wouldn't do it even so.
Old Apr 27, 2014 | 07:55 AM
chuntington101's Avatar
chuntington101
If its a 2-stroke deisel they will need a supercharger to work!
Most people find that they make more power for the same boost presure win turbo only as you don't have the drag of the supercharger! You do get a bolstered low end performance, but not as much as a SC only car as you can't run the SC at peak boost pressure.
Much better to size the turbo (s) correctly for the power you need. If you are really worried about the lag then you can use n2o to help light the turbos off.
Old Apr 27, 2014 | 09:38 AM
c6silver's Avatar
c6silver
They described that Camry like a big block Chevy, an abundance of low end torque and then the quiet rush of turbo top end...doesn't sound like heat soak to me. The blower drive belt was actually putting power back into the engine when under full turbo boost. Read his book...it's really a great book, not just for that either. He has books on turbo and supercharging also. I have all three. He's worked on some really amazing, diverse projects, often along side Bob Norwood, who has done more for forced induction in America than probably anyone...well, maybe him and Corky Bell from Cartech and Ken Duttweiler.
Old Apr 27, 2014 | 09:41 AM
c6silver's Avatar
c6silver
Have you seen that company that has twin turbo kits for 03-04 Cobra Mustangs and GT500s ? I wouldn't call that a waste either...I think it's HP performance. And the 03-04 has a tiny MP112 blower I think, not even a TVS...
Old Apr 27, 2014 | 10:27 AM
greerracing's Avatar
greerracing
Superchargers make heat especially a twin screw on a corvette because the engine bay is so cramped and you cannot fit a very large intercooler brick underneath the supercharger because the hood lines so low this cause a lot of heat. Next when using a twin screw supercharger and turbos the supercharger acts as bottle neck, this bottle neck creates resistance which equals more heat. Plus ls engines really don't need help spooling turbos like 4 cylinders do because of the displacement, I can hit full boost in my 402 cu in vette by 3500 rpms with out brake boosting with twin 62mm turbos. Twin charging is an awesome idea but unnecessary for a vette unless you were track racing.
Old Apr 27, 2014 | 04:15 PM
c6silver's Avatar
c6silver
A TVS isn't a twin screw like a Whipple, Lysholm or Kenne Bell , and, for example, the ZR1 and Edelbrock E-Force kits put the intercooler on top of the blower...Lingenfelter stacked 2 intercooler cores on their new Camaro ZL1.
Turbos make TONS of heat, being that exhaust gas is feeding one side of the turbo, not to mention the compressing of the air to make boost, it's just easier to put a large air to air intercooler in front of the radiator to bring temps back in line with ambient...with a sufficiently large supercharger intercooler radiator and remote tank for cooling water, I don't see heat as being a problem for a TVS with their high helix rotors, especially in a drag racing scenario where you could fill the container with ice water between rounds...hell, while we're at it, run intercooler spray bars on the turbo air to air I/C and shoot some nitrous across the cores while I'm at it.
Old Apr 28, 2014 | 01:11 AM
JETninja's Avatar
JETninja
WA Events Coordinator
Tell that to the Merlins running in P-51 Mustangs and many more aircraft. Turbo & Supercharged and putting out some war winning HP...
Old Apr 28, 2014 | 01:42 AM
Y2KRoadster's Avatar
Y2KRoadster
Bro...it doesn't matter what you have read, or what was done to a Camry. NO ONE does this. There are semi-streetable Vette's and Vipers in the 6's on 10.5 DR's, and plenty that are fully streetable in the 7's...and they are twin turbo'd. It's a neat idea, nothing more. Stop trying to defend something with no proven and sustained results. I'm sure the people you ranted on about know their stuff about the physics behind the application; however, until they can prove it with real, track/street proven results, then it doesn't matter if they have 20 degrees from MIT.
Yeah...because that has something to do with a V8 application. Hey bro, the space shuttle just upgraded it's boosters. Why can't the Corvette's run solid fuel and rockets? They make more power than any supercharger or turbo ever could.
Old Apr 28, 2014 | 06:26 AM
PhysicsDude55
The Merlin engines (production ones anyway) were only supercharged. It did have an interesting 2 speed or sequential supercharger setup that made higher boost at higher elevations to compensate for the thinner air which was a revolutionary idea at the time.
But, then again, the engine made something like 1600 horsepower, as much as 2000hp. But that was from a 26 liter engine. Today there are guys making 2000hp from twin turbo ~6 liter engines....
Again, its a cool concept and idea, but for LS engines, it wouldn't perform much if any better than a conventional turbo or supercharger setup, and it would produce more heat and be more complicated.
If you want more low end boost look into anti-lag setups, its a more practical idea than slapping on an extra supercharger. But then again, the guys with big cube (400+) F/I engines make more than enough low end grunt. If you add more low end torque, you'll just break more tranny parts and spin more tires.
Old Apr 28, 2014 | 08:41 AM
c6silver's Avatar
c6silver
Tell that to Hellion Power Systems and their compound forced induction Mustangs...4.6 and 5.4 liter V8 engines.
Old Apr 28, 2014 | 10:08 AM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Please double check to make sure you are on the correct forum. This is the C5 Forced Induction section of corvetteforum.com. We are not interested in mustangs or camry's or hellion power systems. I'm sure they offer compound kits, but I've never been beat by one at the track or on the street.
I'm not arguing that this concept doesn't work as I've seen it done on other vehicles. As people have mentioned, it isn't the best application on a vette and keeping an ice tank filled on the street isn't practical for me. If you decide to try it out, please post up your results.
Old Apr 28, 2014 | 10:52 AM
c6silver's Avatar
c6silver
Wow. Very opinionated people on here. Was just looking for a civil discussion of the pro/cons of the idea, wasn't giving a thumbs down to anything else...
To Compound Forced Induction
Old Apr 28, 2014 | 11:18 AM
Turbo-Geist
I think people have discussed pros and cons in this thread. Everytime someone mentions an alternative, you bring up a Camry engine in a MR2 or other vendor's compound kits on mustangs. Post up real world results on what those cars ran at the track and how successful they are in competition.
Atleast mention what your goals are for the build. Are you doing this just to do it? Have you ever owned or driven a vette with forced induction? I'm just asking to get a point of reference for what types of power you have experienced in your lifetime.
What do you see as the pros and cons on a C5/C6 corvette with compound boost?
Old Apr 28, 2014 | 12:21 PM
Chicago1's Avatar
Chicago1
ysi in front and sts kit in the rear..lol
Old Apr 28, 2014 | 12:55 PM
c6silver's Avatar
c6silver
I'm good, thanks. Sorry I brought it up.
