what wideband
Old May 6, 2014 | 10:06 PM
digivex's Avatar
digivex
After posting, I went looking... Guess I had much more than I thought.
All PLX...
1. The 52mm (2 1/16") DM 100 gauge
2. Two remotes
3. 02 Sensor
4. the Oil / Fuel Pressure Sensor / Sending unit (SOLD)
5. The OBD II Module
6. The Vac/Boost Module
7. The AFR Module
8. The Fluid Pressure Module (SOLD)
9. The Fluid Temp Module (not sure if this is working)
Here's a pic of the PLX stuff I've amassed: http://i1176.photobucket.com/albums/...0.jpg~original
If interested, PM me an offer I can't refuse and I'll throw it all in a box and ship it out
Old May 7, 2014 | 06:30 AM
StealthFRC's Avatar
StealthFRC
Pm sent.
And y agree on the bulkyness of the sensor, remiss me of the sensor that comes with the crappy glowshift gauges. Thankfully my fpr is in a good location and the sensor should fit.
Old May 7, 2014 | 08:24 AM
digivex's Avatar
digivex
Originally Posted by StealthFRC
Pm sent.
I sold the PLX fuel pressure sensor / sender and module as soon as I posted that list / image last night.
If there are other PLX parts that I listed above that you are interested in, let me know which ones and make me an offer.
PLX uses a VDO sending unit for pressure. Both PLX and VDO market it for oil. But, I used it for fuel and was able to attach it directly into my regulator. I later replaced it with a DynoTune fuel pressure sensor / gauge and then removed that in favor of using a PCS D200 to display every sensor I had in one touch screen display (mounted in my center console).
I'm now selling the PCS D200 as well. At this point, I've kept the Haltech fuel pressure sending unit and will be installing a RacePak IQ3 to display data from all sensors - planning to mount it directly in my dash since I recently removed the PCM from the car.
In addition to the PLX stuff that I still have (sans fuel pressure), I also have the PCS D200 listed that up on eBay at: http://www.ebay.com/itm/Powertrain-C...-/251524195329
