Big Bubba vs Tial 50mm
Old May 8, 2014 | 10:44 AM
Robert 2000's Avatar
Robert 2000
Default Big Bubba vs Tial 50mm
Guys I have an A&A kit si trim with the base 38 mm turbosmart bov. I have progressively increased power and now I am running heads and cam with 3.4 pulley no idea what kind of numbers its putting down. (street tuned) I am about to upgrade the fuel system and want to go to a bigger bov.
I am stuck on the tial 50mm from ECS or the Big Bubba. I need room to grow plans are a built iron block 6.0 with a ysi making 950-1k rwhp in the future.
I like the idea of the big bubba just swapped out with the 38mm then maybe if the big bubba ever gets maxxed out running my current 38mm and the big bubba together?
Old May 8, 2014 | 10:50 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I think the TiAL 50 from ECS is clearly the best answer.
Old May 8, 2014 | 10:54 AM
PEETYZ's Avatar
PEETYZ
Tial 50 FTW
Old May 8, 2014 | 10:56 AM
Robert 2000
How is it normally put into the A&A kit cars do you guys sell a replacement pipe to swap them out or do I just have it welded into the stock location that the current 38 mm turbosmart valve.
Old May 8, 2014 | 11:09 AM
StealthFRC's Avatar
StealthFRC
you need this pipe right here
http://www.siliconeintakes.com/produ...9baf31468700c9
Old May 8, 2014 | 11:25 AM
DOUG @ ECS's Avatar
DOUG @ ECS
We usually send the BOV with a flange to be welded, but I do not know how the A&A BOV is mounted so maybe the option posted above is the best way to go.
Old May 8, 2014 | 11:27 AM
Robert 2000
Does the tial come with the clamp that is reffered to with that pipe shown by the link???
Old May 8, 2014 | 11:33 AM
StealthFRC's Avatar
StealthFRC
yes the valve will come with everything you would need. a weldable flange, the clamp and a o ring, you just need the pipe i posted.
Old May 8, 2014 | 11:56 AM
Robert 2000
I know this is a dumb question but that pipe is the correct length right?
Old May 8, 2014 | 12:19 PM
StingrayRebel's Avatar
StingrayRebel
that's pretty nifty, I've been wanting to get my tial off the end of my intercooler and closer to the blower outlet and this looks like an easier and cheaper way to do that... I can just splice this into the rubber hose and get a couple of t-bolt clamps and have the end of the intercooler welded shut
Old May 8, 2014 | 12:29 PM
StealthFRC's Avatar
StealthFRC
not a dumb question, you would have to contact them to get the exact measurement but it should be the right one. i did not get one from them, one came with my BOV i bought used but its the same thing.
Old May 8, 2014 | 01:17 PM
Robert 2000
I called them and they said it was about 6.5 inches long. A&A has theres listed as 6 inches. I dont see why it wouldn't be plug and play.
Old May 8, 2014 | 01:23 PM
StealthFRC's Avatar
StealthFRC
should work fine, just means the pipe will sit a little further in the silicone
Old May 8, 2014 | 04:48 PM
PEETYZ's Avatar
PEETYZ
I had my shop put the new flange on that is sent with the Tial Q ( aluminum or steel)
Plasma cutter
Old May 8, 2014 | 05:41 PM
Smoove's Avatar
Smoove
JGS 50 or 60 or Tial..or Jodar 50mm.
I like the JGS because of it's valve design....vs the diaphragm design in the Tial for example. The valve, likely will never have a failure,..then diaphragm could. 50 bucks to replace them,..if they go bad.
To make it work...Simple flange/pipe/bead roll to make any of them work.
If anyone needs quality stuff like this, I may be able to point you in the right direction if this thread didn't already.
Old May 9, 2014 | 11:11 AM
Slo-Poc's Avatar
Slo-Poc
Tial you know you like how loud it is
Old May 9, 2014 | 11:22 AM
breecher_7's Avatar
breecher_7
Only thing better than 1 Tial 50mm valves is two 50mm valves!
To Big Bubba vs Tial 50mm
Old May 9, 2014 | 11:34 AM
Detoxx03's Avatar
Detoxx03
Dude stop making being a wuss and just get the tial.
Old May 9, 2014 | 11:49 AM
Robert 2000
True statement
Yea buddy!!! I might add one on the charge tube later on and run 2 when the big build is done
I might order it real soon
Old May 9, 2014 | 11:55 AM
StealthFRC's Avatar
StealthFRC
I have 2 tial 50s one on the intercooler to tb and one in the stock location with the a&a kit
Its quieter with the 2 then it was with one by ALoT
