Considering E85 conversion.
Old May 31, 2014 | 05:56 PM
medblueC4's Avatar
medblueC4
Default Considering E85 conversion.
I have a 2002 C5Z with a NON intercooled Maggie MP112 and LG Motorsports longtubes. Right now I'm making 465 rwhp and a friend of mine tells me I could gain 25-35 hp converting to E85.
I know I'd need bigger injectors (right now I have 42lb). Would my stock pump hold up or would I need to upgrade? Or boost-a-pump?
Matt
Old Jun 1, 2014 | 08:48 AM
medblueC4's Avatar
medblueC4
no response?
Old Jun 1, 2014 | 09:26 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Originally Posted by medblueC4
no response?
Sure: you will run out of pump.
Since your car is 2002, it is very easy to switch to a bigger pump. Furthermore, trying to save some bucks with fuel system is just crazy. I don't mean you would, but as a general comment.
Old Jun 1, 2014 | 10:07 AM
BLWNZ's Avatar
BLWNZ
Matt
You will need to upgrade and do a boost a pump, or and external on top of your stock pump like an A&A or ECS setup. Which will make you ready for an increase in power later on.
Old Jun 1, 2014 | 12:34 PM
Corvette0096's Avatar
Corvette0096
I have the Esc stage one and it's not enough for my 2002 at 17 LBs of boost. 730 RWHP? You will need a big fuel system.
Old Jun 1, 2014 | 01:35 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It really makes very little sense when you look at the $$:power yield ratio.
For the money, I would recommend a small shot of nitrous. Those blowers LOVE nitrous. a 50 shot would cool things down nicely and you can expect to yield about 75 whp from it. With only a 50 shot, you can run it quite a bit before you go through a bottle.
Old Jun 1, 2014 | 10:28 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
E85 complicates matters as you cannot find it at every station. Meth is worse from a maintenance perspective as it adds additional hardware to the car and requires ongoing attention.
I'm sure there are some Maggie gurus around, but you might be able to achieve your goals with a pulley swap or better yet add an IC and a smaller pulley.
To Considering E85 conversion.
