Located: Major Boost Leak
Old Jul 5, 2014 | 12:16 PM
TwinTurboZ51's Avatar
TwinTurboZ51
Default Located: Major Boost Leak
deleted
Old Jul 5, 2014 | 01:22 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Originally Posted by TwinTurboZ51
I was till experiencing low boost on my STS system. I would see around 6-7 PSI when spooling. I had replace Wastegate, Air bridge & coupling and BOV diaphragm. Still not getting system to spool fast enough. I did a complete search of tubing and found the issue. The pipe out of the turbo that goes up to the intercooler has a few brackets welded to it. On each turbo the pipe bolts to a spot where the muffler hanger used to be in the very back behind the bumper.
Apparently last year this chick tapped my back end and torqued these pipes behind the bumper. The bracket on each pipe had broken off leaving a gaping hole where the bracket had been welded on to the pipe. I will replace these pipes in the near future but for now I patched the holes with JB Weld steel stick and now the system spools up normally and hits 10 PSI no issue.
I hope that didn't hurt your turbos. They over spin when they have boost leaks such as that one.
Old Jul 5, 2014 | 09:36 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
If you let a chick tap your back end, you're bound to end up with a gaping hole.
Old Jul 5, 2014 | 10:27 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Jul 6, 2014 | 01:38 AM
JDS99's Avatar
JDS99
Those are the chicks you stay away from. The ones that haven't always been well... a "chick"...
Old Jul 6, 2014 | 03:00 AM
_zebra's Avatar
_zebra
glad you found it. i just changed a few pulleys around today & caused enough belt slip to lose almost 3psi at the top end... but i also expected it
Old Jul 6, 2014 | 09:54 AM
TwinTurboZ51
It wasnt a tranny it was this cute little Asian girl. She fell asleep at the stop light and rolled into my bumper.The bumper had some crinkled paint but I never saw the broken brackets when I was inspecting the damage. I f I had I would have had the insurance company pay for the damages turbo pipes.
Old Jul 6, 2014 | 09:58 AM
BLOWNBLUEZ06
and still aren't
Chicks with D*cks
To Located: Major Boost Leak
