same power, different power adder, same results???
Old Aug 12, 2014 | 10:13 AM
Dtownbrown's Avatar
Dtownbrown
Default same power, different power adder, same results???
Okay so say you have a twin turbo car making "X" amount of power rather than say a procharged car making identical power, would both cars run equal 1/4 times if all conditions and everything are the same?
Reason I ask is my previous car made 720rwhp 719rwt with a twin turbo set up. Now I've installed a procharger kit and makes 728rwhp 725rwt. Same engine/ suspension/ tires etc...
I haven't been able to take it to the track yet but curious to know if it should run close to the same time as the old set up which was 9.98 @ 134 mph.
Old Aug 12, 2014 | 10:31 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
What changed in your camshaft/exhaust to net you 100+ more torque than the turbo setup?
Old Aug 12, 2014 | 10:39 AM
Dtownbrown's Avatar
Dtownbrown
That was a typo. The old set up made 719 torque.
Old Aug 12, 2014 | 10:54 AM
JDS99's Avatar
JDS99
Peak is one thing.. power under the curve is another..
Only one way to find out.. get it to the track
Old Aug 12, 2014 | 11:13 AM
Rj-lo's Avatar
Rj-lo
not necessarily.
its about power delivery. if the power curve is steeper or more linear than it could make all the difference in the world.
Old Aug 13, 2014 | 06:41 PM
stevieturbo's Avatar
stevieturbo
And how well you can apply that power to the ground.
but I'd expect with power/torque that close, for performance to be very similar too. It'll all be down to which gets the best traction.
Old Aug 13, 2014 | 09:24 PM
danieloneil01's Avatar
danieloneil01
Why did you go from a TT to belt problems?
Old Aug 13, 2014 | 09:39 PM
Dtownbrown's Avatar
Dtownbrown
I actually swapped cars, but kept motor/trans/wheels/ etc...the turbo kit was like the upp kit and I didn't want to have to gut the insides of my fenders out and deal with all the oil lines, heat, etc...
Though I did love the power from it, I purchased the car already with twins, and after looking at the modifications it takes to install it I would never do that to my car.
Old Aug 13, 2014 | 10:10 PM
Shane1974's Avatar
Shane1974
The twins in my last car made a wayyy better curve than my centri in this car that makes better power. I miss the twins.
To same power, different power adder, same results???
