question about the window switch
Old Jul 28, 2002 | 12:39 AM
tgeers's Avatar
tgeers
Default question about the window switch
Hi,
I just ordered my NX nitrous system. I have an automatic but ordered the window switch. I wanted to run the nitrous between 3000-6000 rpm. That is why I did not get the WOT switch. I just realized that there will be a problem with this setup. Namely, when decelerating at the end of the run, I will still be in the 3000-6000 rpm range and will be shooting nitrous while I'm trying to stop.
The question is, can I run a WOT switch in conjunction with the window switch so that I'm running nitrous only when in the 3000-6000 rpm range and at WOT? If not, is it safe to use a window switch and then just toggle off the nitrous as I cross the finish line?
I am trying to set up a system that will not give me nitrous at launch. I know I could launch at less than WOT, but it is hard not to get caught up in the excitment of the moment. :) :lol:
Any suggestions will be greatly appreciated.
Thanks.
Old Jul 28, 2002 | 06:20 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: question about the window switch (tgeers)
Get an electronic TPS switch. It basically reads your throttle position and will only trigger if the throttle is greater than ~97% (the percentage is adjustable).
Basically, you use this TPS switch to trigger on/off for the window switch. And after that if your rpm is within the range, the window switch will trigger the nitrous.
When you decelerate, the throttle position will read much less than ~97% which will turn off your windows switch. And that will shut down the nitrous. :cheers:
[Modified by Tuan Le, 4:21 AM 7/28/2002]
Old Jul 28, 2002 | 10:05 AM
tgeers's Avatar
tgeers
Default Re: question about the window switch (Tuan Le)
Thanks,
That is exactly what I want to do. Nitrous at wot and 3000 rpm and no nitrous at the end of the run. :yesnod:
Old Jul 28, 2002 | 10:39 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
you definatly need a WOT switch.. you dont want to spray at 3000 rpm at only half throttle :)
Old Jul 30, 2002 | 07:52 PM
red-y's Avatar
red-y
Default Re: question about the window switch (CHRIS NJ C5)
UPP - get a WOT swich..for sure.. :yesnod:
To question about the window switch
