Purge issues
Old Sep 7, 2014 | 06:57 PM
The black bitch.'s Avatar
The black bitch.
Default Purge issues c6z
I've bumped up from 2-300 shot and put a 6an line ,now I'm having a lot of problems getting it to purge .its along time between nitrous uses some time months . Sat.i had to mess around for 15 minutes before I finally got it stop acting up .pressure was at 900 psi
Old Sep 7, 2014 | 08:28 PM
FourG63 97GST's Avatar
FourG63 97GST
so you're saying you changed nothing else but jetting and it was working before?
I'm trying to what else but the solenoid to blame. could be just a tired purge solenoid
Old Sep 8, 2014 | 06:04 PM
The black bitch.
It's got a white flume come out but when I get on it it bogs I go through same procedure 3-4 times and then it's takes of like a beast. I don't trust to race for $ that's for sure . I wonder the said the nitrous solenoid go be having problems
Old Sep 8, 2014 | 07:46 PM
corvette8189's Avatar
corvette8189
make sure no trash in the lines and check all solenoids.
what solenoids do you have?
Old Sep 8, 2014 | 07:48 PM
The black bitch.
Nitrous outlet
Old Sep 8, 2014 | 10:48 PM
FourG63 97GST
how old is it, could be just tired. at one mine slowly degraded. especially at high pressures above 1000 it's work about 50% of the time. I just switched to an induction solution solenoid.
Old Sep 9, 2014 | 02:36 AM
rich65's Avatar
rich65
Did you try changing any relays
Old Sep 9, 2014 | 08:27 AM
The black bitch.
OK I'll look into I haven't changed the relay or check solenoid
Old Sep 9, 2014 | 09:20 AM
NukeC5's Avatar
NukeC5
One of the main purposes of a purge valve is so that the solenoids don't get tired.. You moved to a 6AN mainline right? Have you made sure it isn't clogged? Do you run a nitrous filter? If you moved up from 4AN, your 4AN filter wouldn't fit if you had one. So I'm assuming you aren't running one. I suggest you purge out the system and makes sure each individual component is working. And get a filter on the system.
Old Sep 9, 2014 | 12:58 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
A few tips:
Bad voltage is often why I see solenoids acting up. Check the voltage across the solenoids during operation. If your controller throws a hot, feed your controller off the back of the alternator and ground the noids to the back of the driver side head. Make good, clean connections. Solder and heat shrink. No wire nuts. butt connectors are second best. Grounds should be to shiny metal, no paint and using star washers to the chassis. Just because it's metal doesn't mean it's a good ground.
Old Sep 9, 2014 | 03:01 PM
C5 Scully's Avatar
C5 Scully
Originally Posted by BLOWNBLUEZ06
A few tips:
I run a full Zex system and it was as you said a bad contact on the bottom of the crimp connector and played-up every time.
I find better to disconnect the line and before the system and a small blow if standing for long as mine... then on to the system and just check jetting and fittings anyway...
could not see it even if you were looking and had to move it to find it intermittent breaking down...
Old Sep 9, 2014 | 07:08 PM
The black bitch.
Yes I have a 6an line I'll check voltage this weekend and if I find nothing wrong I'll get a filter and rebuild the solenoid .thanks for all the replies
Old Sep 9, 2014 | 09:49 PM
BLOWNBLUEZ06
You have to check the voltage AT the solenoid.
Old Sep 9, 2014 | 09:52 PM
The black bitch.
That first thing I plan ,I'm trying make races in a week and right now it wouldn't be reliable runs
To Purge issues
