fuel help
Old Sep 7, 2014 | 08:20 PM
momo20's Avatar
momo20
Default fuel help
so i got my whole ECS S/C kit installed over the weekend..for the fuel i have a fuel 100 psi fuel gauge and boost gauge, i installed my racetronx c5/6 fuel hot wire kit , do i install my BAP up front where the ECS instructions say it goes along with the hotwire kit or just one of the kits/? hope that makes sense
Old Sep 7, 2014 | 08:21 PM
danieloneil01's Avatar
danieloneil01
I installed mine in front of the driver side rear tire inside the wheel lining.
Old Sep 7, 2014 | 08:25 PM
momo20's Avatar
momo20
that is what i have read something to do with the electric being closer to the fuel pump which makes sense..but is having a hot wire kit along with the BAP to much ?
Old Sep 7, 2014 | 09:11 PM
danieloneil01
Doubtful but I also put in a new pump from racetronix while I had everything removed.
Old Sep 7, 2014 | 10:19 PM
StingrayRebel's Avatar
StingrayRebel
I have a racetronix pump/harness and 40a kenne bell bap and that is supporting over 700rwhp, I also have a meth kit... I bought the harness that has the bap wiring integrated into it so it's all plug and play and is mounted in the driver rear wheel well... the hotwire kit just makes sure you get proper voltage at the pump and the bap will boost voltage to the pump only under "x" amount of boost, however the hobbs switch is set up... there is also a controller to limit the voltage boost but I cut and looped the controller wires together so I get full voltage boost when it's on
Old Sep 8, 2014 | 12:24 AM
momo20's Avatar
momo20
sweet thanks that makes a lot more sense now thank you!
Old Sep 8, 2014 | 07:48 PM
Z_fox's Avatar
Z_fox
Hey neutron82 would you mind me asking what pump you are running to satisfy 700 hp? I have my DS tank out now and am installing a GM C6 z06 pump while the tank is out to replace the stock '04 z06 pump.
Old Sep 8, 2014 | 07:54 PM
StingrayRebel
walbro 255 and hotwire harness from racetronix, kb bap, and meth... I don't have any more room to add boost so a new fuel system is in the works
To fuel help
