IAT sensor and MAP sensor for Meth/SD tune
Old Sep 14, 2014 | 05:51 PM
nullpointer's Avatar
nullpointer
Default IAT sensor and MAP sensor for Meth/SD tune
What IAT sensor is everyone using post meth nozzle? I know its suppose to be a fast responding sensor but I only found part numbers for guys with C6's. I am unsure if C5's are suppose to use the same sensor.
What MAP sensor (2 bar) is everyone using? Part number?
Which caspers harness to split MAF from IAT?
http://www.casperselectronics.com/st...oducts_id=1108
or
http://www.casperselectronics.com/st...oducts_id=1137
I did search but most results were for C6s
Old Sep 14, 2014 | 06:08 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
or
Borg Warner WT382
PT778 is the pigtail harness.
I wouldn't bother buying the harness for this. It is 100% reversible back to stock when you're done without difficulty.
Cut the purple and tan wires at least few inches from the plug so that you're able to restore it later if you choose. I personally cut the entire plug off many inches from the end and tape up each wire and then tape them back into the harness, leaving the 2 IAT wires out and attaching them to the pigtail. The wires in the pigtail are the same color because polarity doesn't matter. Pick a wire and splice it into the purple and splice the other into the tan..
Old Sep 14, 2014 | 07:11 PM
nullpointer
Originally Posted by BLOWNBLUEZ06
Borg Warner WT382
Great idea Bret, thanks
Old Sep 15, 2014 | 12:29 AM
RonSSNova's Avatar
RonSSNova
Bret,
Is that sensor shown anything special? Or the same as used in a lot of the older OBD1 cars?
Mine looks the same, but I don't remember where I got it.
Ron
Old Sep 15, 2014 | 08:45 AM
nullpointer
I've found sometimes the GM Cobalt MAP sensor is used. Thoughts?
Also I see Dsteck once had 2 bar sensors with a wide range for sale
http://www.ls1gto.com/forums/showthread.php?t=441457
Old Sep 15, 2014 | 09:31 AM
PEETYZ's Avatar
PEETYZ
Good Info Bret. I will keep that in mind if I add meth this winter.
Old Sep 16, 2014 | 08:45 PM
nullpointer
Bump for MAP sensor details
To IAT sensor and MAP sensor for Meth/SD tune
