From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Boost question?
I was running what I thought to be a 4.38 pulley on my p1sc-1. Come to find out today when I took the pulley off that it was a 4.00. I had ordered a 3.70 to replace what I thought was the 4.38 pulley. I made 5-6lbs of boost with the 4.00. Is that about right? How much boost should I be making with the 3.70? I was making 557 rwhp on the 5-6lbs with the 4.00. I did notice the belt on the 4.00 pulley had a good bit of slack in it. May have had some belt slippage. With the new belt and this 3.70 pulley, the belt is super tight! Was the boost about right for the 4.00 pulley? Mods are in signature.
I don't know the timing, but I could find out from my tuner. I run only 93 octane, 243 heads and ls6 intake. Everything from what a true z06 would have.
Gotcha so same as me. Yea expect about 600 or so on about 11psi with the 3.7
