My question is with the use of the wotbox and methanol when using the unit to do full foot to the floor shifts. The idea of this box is to allow you to pull a bit of spark when the clutch is depressed to make it easy on the tranny and keep boost full by not lifting on the throttle through shifts. My question is because I use methanol and it doesn't cut fuel or math from spraying will the methanol cause an issue between shifts as spark is pulled while the clutch is depressed. The fuel continues to flow during this time but it usually backfires a bit due to unburnt fuel. Any thoughts on this would be great. Any experience ?
