Cam and heads for twin turbo
Hello
I have an 01 vert, stock except for twin rear turbos, 3:42 rear and yank 3200 stall. I'm considering a different cam and maybe heads, what should I buy?
Assuming my current HP at crank is 550 at 8 psi of boost, what would be the approximate HP gain for a cam and then heads?
I really like the ported LSA heads they have a thick deck and good flow and are very affordable
what cam do you have now?
good conv and you want to match the cam with the conv and the intended RPM range of engine
work with a good vendor to match with your needs and tell him how you will be driving and using the car
cool car
cool car
cool car
cool car
