Boost Controller
Old Nov 23, 2014 | 02:29 PM
hak's Avatar
hak
Default Boost Controller
I have a LS1 with cam, headers and STS twin turbos. The wastegate is F8 TIAL with a .7 BAR (10.2psi) spring. I take the vette to my tuner (he is the best) and after he finishes the graph shows 530whp. The problem is the wastegate opens at 10psi but then the wastegate can’t control the boost after that. The boost oscillates between 7 and 9 psi with the average of about 8.5psi. The engine is capable of handling 10psi so I don’t want to settle for 8.5psi.
I email TIAL tech support and they respond that I need a larger wastegate. I can’t do that because the wastegate mounting in the exhaust is designed to only take the F8 TIAL.
I am thinking a mechanical boost controller may fix my problem. I am asking the Forum members if they think that a mechanical boost controller will solve my problem. If it will solve my problem, what controller do you recommend?
Thanks for your help.
Old Nov 24, 2014 | 12:12 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
You can use a cheap $10 Ebay to a $150+ Hallman to test your theory. I'd believe a mechanical Hallamn would work well, bu tthe cheapest one is like $65. Turbosmart and a couple other manufacturers all sell manual controllers.
I use TurboSmart Eboost Street controllers in my turbo vehicles.
Old Nov 24, 2014 | 01:31 PM
JDS99's Avatar
JDS99
I'm actually pulling the Eboost Street out of mine currently in preparation for the Haltech switch. I'll cut you a deal on a very lightly used Eboost street if you're interested. Have 2 boost solenoids for it. Shoot me a PM if interested.
The eboost has a setting to accommodate boost falling off up top. Splice into rpm signal, tell it what rpm the boost starts to drop from target, and give it a pressure ratio for the amount dropped. Done. Not uncommon for running just springs, or even mechanical controller.
Old Nov 25, 2014 | 12:15 AM
StatmanRN's Avatar
StatmanRN
I have almost the exact same setup and power level and upgraded turbos. Gauge is steady at 10 with a mechanical controller
I seriously doubt the size of the gate is your problem if its to air rather than an exhaust system
I am looking into an electronic controller for better spool, at least 2 power settings and possibly boost by gear for my new build. Leaning toward the HKS or Apexi.
I have also considered a 2nd gate with a mech controller as a safety just in case
Old Nov 25, 2014 | 12:53 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I don't understand why your boost is oscillating under your target and you're told you need a larger wastegate. My experience is when the wastegate is too small, your boost creeps above your target, not below.
Have you or your tuner performed a boost-leak test? You can clamp caps on both turbo inlets, pull your brake booster line and hit it with boost from there. If you have a boost leak, it could cause this issue and destroy your turbos, making them over spin and ride the choke line to their death.
Old Nov 25, 2014 | 09:05 AM
hak's Avatar
hak
Thanks for you input. What mechanical controller are you using? Did you have a steady gage before you added the controller?
Old Nov 25, 2014 | 09:15 AM
hak's Avatar
hak
Old Nov 25, 2014 | 05:14 PM
FourG63 97GST's Avatar
FourG63 97GST
Agreed, I'll start here. too small of a wastegate will cause boost creep.
based on the logic you got from Tial. the wastegate is too big and bleeding off too much.
But I wouldn't overthink it, try a boost controller
Old Nov 26, 2014 | 09:14 AM
hak's Avatar
hak
Thanks for everyones help and advice. It looks like I need to install a boost controller. The one thing I don't understand about electronic boost controllers is that some manufactures claim to be able to increase the turbo spool up. I don't understand how this is possible. My understanding is that the spool up is limited by the volume of exhaust gas spinning the exhaust side of the turbo. Can an electronic boost controller actually increase your spool up? If they can increase spool up, how is this done?
Old Nov 26, 2014 | 12:19 PM
JoeyG's Avatar
JoeyG
Say you have an 8# wastegate spring. Usually the spring will start to creep open at say around 5-6#'s and progressively open full by 8#'s. With a boost controller the wastegate isn't allowed to vent/move until there's enough pressure to overcome the wastegate spring and controller combo. That is where the claims for increased spool come from.
Old Nov 26, 2014 | 12:42 PM
hak's Avatar
hak
Thanks for the explanation. Makes total sense when you explain it that way.
Old Nov 29, 2014 | 02:24 AM
StatmanRN's Avatar
StatmanRN
Its a basic mechanical controller, not sure of brand or if it came from STS originally. I bought the kit used, it was installed and tuned with it so no baseline.
The thinking with the electronic boost controls helping spool is that they stay shut untill the target due to the solenoid, whereas the wastegate spring begins to open sooner left to its own devices.
Old Nov 29, 2014 | 05:47 PM
stevieturbo's Avatar
stevieturbo
No additional controller will be a fix for an inherent problem.
Fix the actual problem, dont try and band aid it.
Old Nov 30, 2014 | 09:16 AM
2quick98's Avatar
2quick98
Sounds like a leak to me u shouldn't fluctuate that much check for leaks
To Boost Controller
