Broken LS2/3/7 Timing chain leads to PEETYZ 2.0 for 2015
Well as luck would have it the very first day of winter a month or so back it was nice enough for a drive in Ohio. A little cruise later on a country road 3rd gear about 5,000 rpm the motor made a small back fire and just felt like the key was turned off. Went to start it back and the motor had no compression but all the accessories etc were turning... yep crank was no longer connected to the cam. Of all the ways for it to go out I wouldnt have thought it would be this. I changed to the LS3 larger timing chain when I did build first time.
Pulled the heads and heres what my valves looked like on both sides of the motor:
All was not lost
Glad the 01 Z did not have sodium valves or it could have been worse.
They made marks on the pistons but did not crack or break them.
It was now or never to build the motor
Time to tear it down:
Few hours later
I used an ATV jack to support the cradle. The Engine hoist was large enough to straddle ATV jack to pull the motor and the TQ tub was supported by floor jack and jack stands. Not the easiest in the world but not the worst either.
Heres the problem
Found the pieces to the broken link in the oil pan. Luckily it didnt go through the motor.
I recently got a deal on an 04 GTO short block off a friend with a spun rod bearing and decided to build it and refresh my stock short block for with the good parts between the 2.
Planned build.
04 LS6 Block
Wiseco Pistons -3cc
Stock Crank
Lunati rods with arp 2000 bolts
C5R timing chain, C5R timing chain, C5R timing chain
D1Sc or Novi 2000 Blower
Larger fuel system
Meth
RXT clutch
Ported 243 heads
ARP head studs
ls9 gaskets
larger Blower Cam
More
I will post more details as they come. Currently at engine shop.
Not going to be a cheap winter for me but Big thanks for the the help and support thus far
All was not lost
Few hours later
Heres the problem
Planned build.
04 LS6 Block
Wiseco Pistons -3cc
Stock Crank
Larger fuel system
Meth
RXT clutch
Ported 243 heads
ARP head studs
ls9 gaskets
larger Blower Cam
More
Well as luck would have it the very first day of winter it was nice enough for a drive. A little cruise later on a country road 3rd gear about 5,000 rpm the motor made a small back fire and just felt like the key was turned off. Went to start it back and the motor had no compression but all the accessories etc were turning... yep crank was no longer connected to the cam. Of all the ways for it to go out I wouldnt have thought it would be this.
wow c5r chain??..i thought thet did NOT break?...sorry
now u got me thinking about mine...whats a better chain?
The C5R is stronger and what I am using this time. The C5R team never broke one. I'm not sure if anyone else has but the reputation is really good. Very uncommon to break a timing chain in general but things happen. Part of the game.
Thinking about it it was 600+ rwhp stock bottom end no meth for a few years with countless mexico runs holding its own with some stout cars I can't be that upset. The fail had nothing to do with the tune and honestly the stock bottom end is OK. Yes the valves hit the pistons but the pistons did not break. Would I re use them? no
Gotta pay to play and this time it will just be bigger and better now
Pistons came in =) Off to the machine shop today
Some ls1/6 had the holes but they are spread out more than ls2 style. GM sold these older guides as a aftermarket part, but since has discontinued them. I think some have remade them and you can fit the tighter hole pattern of the ls2 but it is super close to not hitting the pad when drilling and taping. Trick flow also has a piece that mounts on the cam retaining plate.
I have drilled and tapped two blocks for the ls2 style but as I said above its tight. My car has the factory GM ls1/6 part that I found back in the day. I think Katech might have remade the old one or check out the trick flow deal.
