[E85 and C5 Corvette Compatibility]
Old Feb 9, 2015 | 05:52 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Default [E85 and C5 Corvette Compatibility]
I'm seriously considering using E85 this time around. Does anyone know which parts in the factory fuel system are not compatible with E85?
  • Let's assume that you have an external pump, aftermarket regulator, fuel rails, and ethanol compatible braided hose.
  • Is a Racetronix 255 in tank E85 friendly?
  • Is the stock transfer line between the tanks and the jet siphon pump compatible?
  • Are the plastic factory feed lines ok?
  • Any other items to consider or change out?
Old Feb 9, 2015 | 10:14 PM
inspector12's Avatar
inspector12
Pretty sure all the stock stuff IE: transfer lines the siphon pump and level indicators as well as the factory feed lines.
http://www.autoblog.com/2007/08/07/can-any-car-use-e85/
Old Feb 9, 2015 | 11:45 PM
Milan's Avatar
Milan
Everything is compatible in modern vehicles. Been on E85 for 4 (?) years now.
Old Feb 10, 2015 | 12:31 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
I've been considering running it too! I'm not sure if I'd have to replace the filter socks on my fuel pumps though.
Old Feb 10, 2015 | 12:39 AM
Gregster's Avatar
Gregster
Do you test ethanol content before each fill up?
Old Feb 10, 2015 | 11:57 AM
Smoove's Avatar
Smoove
The problem is if it sits in the vehicle for LONG periods of time.... injectors,...or pumps, SOME fuel lines...could deteriorate. If you daily it or use it often, you would likely no have an issue. Stabil or other stabilizers can be added to a tank to provide lubricant when storing.
That said....highly recommend E85.
Old Feb 10, 2015 | 01:11 PM
PEETYZ's Avatar
PEETYZ
None of you are running the flex fuel sensor with the C5 computer right?
Old Feb 10, 2015 | 01:55 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
There aren't ethanol content tables in the C5 PCM's or pins to hook a sensor up to.
Old Feb 10, 2015 | 02:10 PM
Smoove's Avatar
Smoove
straight e85
Old Feb 10, 2015 | 02:20 PM
Shoaf85's Avatar
Shoaf85
I've been running it for about 1.5 year now without issue. All the lines to/from my secondary pump along with filters and regulator are E85 compatible. But other than that I'm running a standard Walbro 255 in tank and all the factory feed/crossover lines are still being used as well. I fill up a 55 gallon barrel and keep it in the garage. I check the alcohol content with every new barrel and haven't had to make any adjustments yet (so far 90% every barrel). I think I am about to cut it down myself to about E70 now though to give me some headroom with my injectors since they are pretty much maxed.
Old Feb 10, 2015 | 02:48 PM
Smoove's Avatar
Smoove
nice. Whats it cost for a 55 gallon drum? Curious if it comes in a plastic, or steel drum. Plenty of E85 around me but...just curious...in case I was feeling lazy or traveling to an event.
Old Feb 10, 2015 | 02:56 PM
Shoaf85's Avatar
Shoaf85
I actually take a plastic 55g drum with me in the truck to the only pump around here and fill it up LOL. Sorry for not being specific.
I have looked into ordering drums of E98 and mixing my own but it gets pricey real quick when going that route. I will stick to my $2 race fuel for now
Old Feb 10, 2015 | 03:11 PM
Turbo-Geist
Thanks everyone. Good info and I'm liking what I'm hearing.
What kind of stoich value are you entering and what lambda are you commanding?
I know on 93 and meth, I would run slightly leaner during spool-up, richest at MBEP and then hold till redline.
Does E85 respond to similar tuning methods? :
Old Feb 10, 2015 | 03:18 PM
5 Liter Eater
St. Jude Donor '11
Ben you will need upwards of 1.4k injectors for corn.
Old Feb 10, 2015 | 03:42 PM
Turbo-Geist
How does 2.0k bushels of corn sound? Farmvette can probably plow that in an hour.
Old Feb 10, 2015 | 03:45 PM
Shoaf85's Avatar
Shoaf85
I've been tuning mine with the same equivalence ratio (1.28) as I do with regular gas. For wot under boost I command roughly 11.4 afr on a gas scale which is roughly 7.5 afr on E85 scale, I'm still on stock internals so I haven't pushed it any further with a leaner ratio. My stoich value in tune is set to 9.7.
Old Feb 10, 2015 | 03:53 PM
5 Liter Eater
St. Jude Donor '11
2k's sound good. Thats what I'd get. My worry is that I've had to scale my tune 50% to fit the 1k's and would need to do that again for the 2k's. Seems like a lot of resolution loss.
To [E85 and C5 Corvette Compatibility]
Old Feb 10, 2015 | 04:08 PM
Shoaf85's Avatar
Shoaf85
Just to throw this out there just for some reference. I am running DW 95lb injectors. My base fuel psi is 65 so they are actually 108lb inj at that pressure and I am running a boost referenced system on 14 psi so far it traps 125mph in the 1/8 155+ in the 1/4 @ 3300 lbs. I havent had it on the dyno but with that MPH and weight its making roughly 900whp and my duty cycle is 98%
Old Feb 10, 2015 | 08:57 PM
JDS99's Avatar
JDS99
Ben, I would just make sure you're using viton seals on all the new stuff and regulator is alcohol compatible. Wouldn't worry about the transfer lines as much since they're low pressure anyway. Not sure on the filter socks in the tanks.. Our earlier ones use a big sock on PS tank siphon, the 01 and later don't have a sock on them. Probably not a big deal though.
I'm planning on corn myself, but switched to the Haltech with flex sensor. Regular pump last fill had 8% alcohol. During the winter they dilute the E85 down, so would want some sort of content sensor at the very least if using stock PCM still. I don't remember what the % was Bret told me when he put some in his car last, but it was significantly under 85%.
You might be able to do something cheap by putting a Continental GM flex sensor in your return line, give it 12V and measure the frequency on output wire. 50hz = 0% alcohol, 150hz = 100%
Old Feb 11, 2015 | 12:07 AM
Milan's Avatar
Milan
Nope. Boise never goes below 75%..
Also my car sits for months at a time...no issues. But for those of you who are convinced you need X in order for it to work I'm sure there is a company who will be happy to profit off you.
