twin .63??
Old Apr 29, 2015 | 12:24 PM
WIKU's Avatar
WIKU
Default twin .63??
Will .63 turbine support a 418ci engine??
I have a brand new turbo from my 4 cylinder days that never got used. When I bought it , they said it would make 500hp.
I'm looking to do a twin setup, so I would just buy 1 more.
Let me know thanks
Old Apr 29, 2015 | 01:04 PM
Blackonblacksls's Avatar
Blackonblacksls
Seems small. Really small if it's a t3 like I assume a 4 cylinder turbo would be
Old Apr 29, 2015 | 01:35 PM
WIKU's Avatar
WIKU
So what size should I be looking for ???looking to to twins in the front fender
Old Apr 29, 2015 | 01:38 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Do you have any more specs on the turbo, i.e., compressor and turbine wheel sizes, t3/t4 housing, etc.
Without additional info, I'm going to initially say that it will spool quickly but run out of steam before 6,000 rpm.
418 ci usually wants at least 0.82 a/r on the turbine side.
Old Apr 29, 2015 | 01:45 PM
Blackonblacksls
I think people seem to have the best luck with 6266 or 6766 and the biggest ar you can get
Old Apr 29, 2015 | 03:10 PM
WIKU's Avatar
WIKU
I don't have any info on the turbo. It was bought many moons ago. Either way, it's a t3/to4e setup.
With a .63 turbine. ---so too small for sure right???
Reason I'm asking , a guy at work with a 4 cylinder wants to buy it.
So I need to sell and buy 2 larger hair dryers that will fit my 418
Old Apr 29, 2015 | 03:15 PM
WIKU's Avatar
WIKU
I need to make no less than 800rwhp
Old Apr 29, 2015 | 03:50 PM
cmiller8006's Avatar
cmiller8006
You,need a .82 or bigger ar. I ran .63 on my 2.0 liter.
Old Apr 29, 2015 | 04:09 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
That A/R is small for the cubes. Not ideal but it'll work. What compressor and turbine wheel sizes?
Old Apr 29, 2015 | 04:18 PM
Turbo-Geist
If you want 800 rwhp or greater, here are a few options for twin turbo:
Precision 6266's
Garrett GTX35R's (make sure it's the X)
UPP 6182R's
These turbos are sized perfectly for starting at 800rw and going to +1200rw.
Old Apr 29, 2015 | 04:23 PM
5 Liter Eater
St. Jude Donor '11
Ben you and I both know from experience that even a 58mm .63 AR will make north of 800 (well, two of them).
Whats the "X" do?
Old Apr 29, 2015 | 05:51 PM
slow ride's Avatar
slow ride
Gtx is the newest billet version. .63 will work look at the guys running the ttix kit that had 6266 with a .63 housing. OP needs to know the wheel sizes as a t3/4 has a huge range of potential. I think the turbine wheel size makes more difference than the housing to an extent.
Old Apr 30, 2015 | 12:53 PM
Smoove's Avatar
Smoove
Open wastegates, largest dp's possble...probably get you to 800rwhp on two of them(.63)...depending on turbo. It would just lite up QUICK..maybe a little choked out up top but..that depends on where you're shifting at.
Old Apr 30, 2015 | 04:15 PM
Turbo-Geist
Whats the "X" do?
The GTX has redesigned compressor and turbine wheels. The map is extended and you get more lb/min than the regular garden variety 35R.
My Turbonetics 58mm turbos had the 0.82 a/r housing and all though they really sparkled at close to 900 rwhp, they were being pushed. It was to the point that I would be concerned about the reliability long term, but nothing lasts forever. Mine made 20,000 miles and were bought used. Now they are going on a TT 5.3 in a Malibu as is.
Spool wasn't an issue. They made full boost by the 30 foot mark without a two step.
He mentioned "no less than 800hp" and to me that means you're on the path to 1000+ but will need new turbos to get there. If the OP wants to throw on two 0.63 a/r turbos and squeak out ~ 800 crank hp, that's perfectly fine.
Old Apr 30, 2015 | 05:50 PM
Smoove's Avatar
Smoove
We put GTX wheels in my older precisions.
Old Apr 30, 2015 | 05:58 PM
Turbo-Geist
Have you tested them out yet?
To twin .63??
