Nitrous question
Old Apr 30, 2015 | 07:48 PM
03YellowZO6's Avatar
03YellowZO6
Default Nitrous question
I have a 03Z and I am getting ready to wire up my Nitrous Outlet wet kit. What's the biggest hit the stock fuel pump can handle and how do most people activate their nitrous system's WOT switch? Is the digital WOT switch the way to go or is a mechanical switch activated by the gas pedal? I had a 4th Gen F body that I used to spray the hell out of with a TNT wet kit so I am no stranger to the juice but I also had a friend with a Silverado SS grenade his motor when the switch under his pedal stuck.
Old Apr 30, 2015 | 09:47 PM
mcshocks's Avatar
mcshocks
But yourself a window switch with a TPS activated WOT built in
Old Apr 30, 2015 | 11:34 PM
03YellowZO6
Thanks for the input. Somebody was telling get the NOS brand WOT/Window switch and that the Nx one has problems. I can't remember who it might have been on here even.
Old May 1, 2015 | 12:57 AM
c_white's Avatar
c_white
Nos wot/window switch here and I love it, easy to use/set up. nitrous outlet will soon have their own wot/window switch for sale this summer I'm told.
Old May 1, 2015 | 03:24 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I used a wot switch at my gas pedal. It was cleaner to install versus tapping the tps and doing that learn procedure. Additionally, I did mine long ago so I used the fjo controller and just tapped my rpm signal. I did not want to hack up a bunch of my cars wiring that is why I used a wot switch.
Old May 1, 2015 | 05:19 PM
S400z06's Avatar
S400z06
^^ what controller did you use?
Old May 1, 2015 | 06:06 PM
c_white's Avatar
c_white
Nitrousoutlet sells a bracket for that already in the kit for the peddle, but I've heard too many horror stories about that messing up and I was told to just get the nos controller to eliminate all possibilities of something not reading right. I know a ton of tuners that won't even mess with ur car if it doesn't have the nos wot/window switch. If u check out the nitrous section over at ls1tech.com they have a ton of information on how set up systems.
Old May 1, 2015 | 08:19 PM
mcshocks's Avatar
mcshocks
Reading TPS is much more accurate than relying on a mechanical switch on a bent bracket. I've watched many miss getting a hit because there bracket bent. If you do the wiring correct there's zero hacking involved, heat shrink & solder & you'll be fine. I don't mind WOT switches on carbed cars because it's pretty easy to setup on a throttle linkage but on a DBW car putting one on a pedal that just takes a beating scares me.
Old May 7, 2015 | 06:01 PM
NitrousOutlet's Avatar
0NitrousOutlet
Former Vendor
Using a Window Switch or Progressive Controller with built in TPS activation is the best way to go. Not only do you get a very reliable signal, but it can make for a very clean install when done properly. If you're using the car mostly as a street car, I'd recommend the NOS Mini 2-stage Progressive Controller. Not only does it have a built in window switch and TPS activation, but it's progressive functions are very easy to program. It's a very reliable unit with a pretty basic install.
-Andy
Old May 8, 2015 | 02:36 PM
0NitrousOutlet
Former Vendor
First, I want to get some info on your build.
You have a 03Z, I am assuming you are still on the 18's in the rear? Are you on street tires or a set of radials or slicks?
What is the most you ever plan on spraying?
-Lance
To Nitrous question
