Belt Change
Old May 9, 2015 | 09:14 PM
SuperVetteC5's Avatar
SuperVetteC5
Default Belt Change
Ok guys, haven't done this before. I've got a 2004 Z06 with an A&A V-3 supercharger. Gonna change from a 3.8" to a 3.6" pulley. Any tricks to changing the belt. Everything a real tight fit as you all know. Will have to at least loosen the Supercharger to change the pulley, I can tell that much. Anyone have any pointers, what needs to be removed, how do I get to the spring loaded tensioner, etc? Thanks for your help. My first late model Vette so just want to do things right and with as little hassle as possible.
Old May 9, 2015 | 09:29 PM
rodsvet's Avatar
rodsvet
Mine is the earlier design bracket where you pretty much remove the supercharger from the car to thread the belt onto the tensioner. If you have the later design you don't have to remove nearly as much. I think A&A has a video on their site. Good luck, rod
Old May 9, 2015 | 10:18 PM
chris308's Avatar
chris308
I believe theres a youtube video showing a belt change.
To Belt Change
