Hey I remember your post a while back you were disappointed with the dyno #'s from the new motor just curious what was the problem? Nice setup you have
hey bud....Compression turned out to be 8.8:1 on the last build. I also added a better intake system to the blower and 2" hearders.
I am really interested to see more detailed dyno sheets, as this is the closest to my setup I have seen yet. From the sheet you posted your power comes in a little earlier. I wonder if this is due to the slightly smaller pulley, the more timing, or both. I have that 2.85 pulley but never tried it. Maybe I should.
Anyways, watching with interest... great looking ride.
I will call Champion today and have them send it to me and will post. I can also confirm the afr was 11.15 on this pull as per the tuner.
Hey Drew, Where in Ottawa are you? I've just recently moved back to the area from the US. Would love to meet up with you some time and check out this monster.
