small blower, head bolts vs studs
Old Jul 20, 2015 | 12:48 PM
BURL's Avatar
BURL
Default small blower, head bolts vs studs
Did a search and didn't find good answer. I am about to do an ECS 1500 blower. 90% Street driven 2003 LS1. Occasional grudge run likely. Mild blower cam. RPM limited to approximately 6200. Boost likely in 8 - 10 PSI range. Now the question:
I will be pulling the stock heads to install ported LQ9 heads at about 10:1 compression. While heads are being changed is it wise to do ARP studs at this level of power/boost or would a set of ARP head bolts be sufficient? I am on a budget so sticking with the bolts would be preferred.
Experienced opinions and advise appreciated. Thanks
Old Jul 20, 2015 | 01:19 PM
Milan's Avatar
Milan
ebay head studs...I would not waste money on head bolts for anything boosted ever
Old Jul 20, 2015 | 01:31 PM
nullpointer's Avatar
nullpointer
studs ftw
Old Jul 20, 2015 | 03:43 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
ARP Bolts are more than sufficient for your use.
Old Jul 21, 2015 | 03:07 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
IMO the ebay studs are ~as good as the standard ARP 8740 studs which are plenty for what you need. I ran ebay studs over 900, lifted a head with real ARP 8740's @ ~1100 and upgraded to ARP CA625's after that and now I have those 625's with additional six bolt studs on my LSX/All Pro motor.
Old Aug 4, 2015 | 12:46 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
There are obvious advantages to using an aftermarket bolt or stud over a factory bolt.
There are also advantages to using a stud over a bolt.
Not all studs or bolts are created equal.
I'd be pissed off if I trashed an engine over wanting to save a few hundred bucks. You probably don't need a $1,000 ARP 625+ stud kit but you certainly ARP has something that will fall with in your budget and give you that piece of mind knowing you have a good product.
As for the offshore studs you can find on eBay, they could be just as good. I don't know. I've never used them. I personally probably never would. I seem to have to end up spending double or even triple the amount of money is normally spend when I try a "just as good as" product.
To small blower, head bolts vs studs
