Turbo PCV System
Old Jul 20, 2015 | 02:52 PM
TheBigDog's Avatar
TheBigDog
Default Turbo PCV System
CAn someone tell me how to find the barb on the driver sidevalve cover. I can not feel or see the d*** thing. The car is a 2000. Drawings show it on the back side under the cowl on the drivers side. Thanks
Old Jul 22, 2015 | 05:18 PM
Milan's Avatar
Milan
LS6 has it, LS1 won't
Old Jul 22, 2015 | 06:16 PM
JT FRC 00's Avatar
JT FRC 00
Default LS1 driver side rear valve cover port
Here is the port on the valve cover in the rear under the cowl your looking for. It's right behind the bolt with the rubber hose going to it. It's a 90 degree fitting
Old Jul 23, 2015 | 09:31 AM
PEETYZ's Avatar
PEETYZ
Mine did not have a fitting on it. It was just a smooth plug. I am going to swap in another with the fitting and run each valve cover into a breather can.
http://www.jegs.com/i/JAZ+Products/5...75-01/10002/-1
To Turbo PCV System
