Max safe boost for Magnacharger
I know the 03 Cobra guys are doing that, but their 7.5-8 psi has an air-water intercooler, thus they can swap to smaller pulleys to up the boost to a good 12 or so on top of the forged internals and lower 8.5 compression engine and be fine.
ZZ
A Common Question: "I installed a set of ported heads with no other changes and my boost level dropped. What is happening?"
The Answer: In this instance, the improved flow of the exhaust ports on the new head allows the engine to more efficiently get rid of the burned gases. The blower is not building "psuedo boost" trying to push out the remaining exhaust gases. Although the boost pressure is higher, less air is actually being forced into the engine because of the restricted exhaust and power is limited. With a better flowing exhaust, more air is forced into the engine because the blower is not also trying to force out the exhaust byproducts. The boost pressure is lower, but the mass of the air entering the cylinders is actually greater.
Stated another way, boost pressure is a measure of how restrictive your intake and exhaust system is. The more restrictive your system is, the higher the boost number will be. Restrict your exhaust flow and you may see your boost rise, but your power will actually fall off as the blower uses more energy tryng to push against this back pressure.
Trying to spin the blower faster in an attempt help "push out" the spent gases may help slightly, but it may actually hurt power. As a Roots type blower spins faster, its adiabatic efficiency drops. This means that you are heating the incoming air more than compressing it. As the air is heated it expands and although the apparent boost pressure rises, there are actually less air molecules per unit volume and less air means less power.
This point is outlined in the October 1998 issue of Automotive Industries, a highly respected automotive engineering industry trade magazine in an article titled "Eaton Boosts Engine Aspirations" by Don Sherman.
"Compared with supercharged engines offered by the imports, GM's Series II 3800 V-6 uses lower boost pressure and no intercooler, note GM Powertrain engineers Bill Owen and Robert Gardner. The GM engineers regard boost as a measure of inefficiency - GM uses 7.5 psi, only 2/3 as much as Jaguar. Boost is the pressure required, above atmospheric, to push the charge through the engine to make power. Less boost for a given amount of power means more efficient flow, because heat and parasitic losses both rise with boost pressure."
Another important point made in this article is this:
"Superchargers are highly tunable. By adjusting the crankshaft-to-supercharger drive ratio, OEMs can schedule air delivery low in the rpm range, for extra surge from a stoplight, or up-register for enhanced passing performance.
What this means is by changing the size of the supercharger pulley, one can optimize the power output to favor high RPM horsepower, or low RPM torque. We've seen this in testing on the dyno where decreasing the size of the blower pulley beyond a certain point results only in more low end torque with diminishing gains in upper RPM horsepower - the smaller you go, the more the high RPM horsepower is sacrificed. Therefore, the optimum pulley size is one that balances the low end torque and high end horsepower, and is very dependent on how efficiently the exhaust can be expended.
Also: http://www.thrashercharged.com/L67_htm/pulley.shtm http://www.thrashercharged.com/L67_htm/dynodata.shtm http://www.thrashercharged.com/L67_htm/intercooler.shtm
Rhino, what do you think given this info, can we do the 7.5 lb pulley to get more tq and response at a lower rpm while sacrificing some hi-end hp?
[Modified by Steve02C5, 4:25 AM 8/21/2002]
As for GM's philosophy with using a moderate boost non-intercooled setup, I think (in additon to what's mentioned) that they use that particular setup because of reduced costs and complexity of running non-intercooled, putting a lid of boost pressures limits the driving force one needs, and eliminating the intercooler eliminates further drive losses. Of course with higher dollar euro imports all this is less important compared to the loftier performance targets, hene higher boost pressures and intercooling is used.
Fortunately, for many recent years, GM's 3800 S/C started out with a good foundation and their modest requirements to stay at the top of the class in straight-line acceleration only required moderate nonintercooled boost pressures thanks to a fat blocky boost curve. As competition heats up, they may well resort to higher boost pressures and intercooling.
