383 build below expected results
If it was locked, you are down atleast 100hp...or more. Hard to say without all the data and a good chart to analyze...
Take it to the track and see what it runs... If it goes atleast 132-133, you are probably ok.
I will try to get more info from dyno
The question should have been "has anyone with this combo and the small blower (si trim) had trouble getting over 500 hp?" and stuck to that(sorry), I was told by a very reputable guy I may have problems......looks like he was right! Seems everybody else thinks the car should be doing better?
Thanks again for all the info.
The tuner will know for sure if he locked it or not. Another way you can sometimes tell if it's locked or not is by looking at the torque curve on the chart. If the car has a stall speed converter and it's unlocked, it will usually have a big spike on the torque right at the start of the pull...and the peak torque numbers will be unusually high due to the torque multiplication from the converter flashing.
I think he did the best he could, I was not there but they had a few things that croped up (tranny line blew, pcm would not load last tune). I think I got some bad advice about the motor to order for the blower I had? It seems to have a lot of torque early, but hp tops out and falls off, I'm still waiting for an actual dyno I can read.
Joe,
You going to melbourne this weekend?
Joe,
I am 154 (NCCC) in the country right now. I am determined to drop
lower on the list (ha-ha). I am glad I didn't tell you what my
hp numbers were, the last time we talked. My little 346 cu
puts out a lot more hp than your bigger engine. As you have
figured out it's all in the right combo of parts. And just remember
it's not the number but the performance of the engine that counts. See you soon.
soon.
soon.
I was dissapointed in the final number, but the motor runs well, I mostly got what I wanted the bigger motor has lots of torque down low and thats what I feel when on the gas
he did say it was a bear to dial in this car. He said "the AF should have been on the bottom and around 11.5/1 and 15* of timing up top", I asked him if it was a "conservative tune" and he said he tunes conservative as if it was his car but said he would only be 10 to 20 hp from max. He said converter was locked and data did not show much slip. I can't really ask him to do better because he is out of state guy that my mechanic hired. So I realize when I get my car back I will have to find a local/ in state tuner or do it myself with data logging and help from the pros on here.
he did say it was a bear to dial in this car. He said "the AF should have been on the bottom and around 11.5/1 and 15* of timing up top", I asked him if it was a "conservative tune" and he said he tunes conservative as if it was his car but said he would only be 10 to 20 hp from max. He said converter was locked and data did not show much slip. I can't really ask him to do better because he is out of state guy that my mechanic hired. So I realize when I get my car back I will have to find a local/ in state tuner or do it myself with data logging and help from the pros on here.Well.. If all he told you was true, and he did tune it to 11.5 AFR, 15* and the converter locked, that's about all he can do for you...those numbers are definitely in the ball park..
IATs, KR (knock retard - timing retard from too knock sensors picking up knock) , timing retard from high IAT, heat soak from high engine temps etc, boost leaks, belt slip could ALL have an effect on power output and all of these variables need to be monitored while dyno/tuning.
You could throw it on another dyno, have them set the smoothing on 5 on the dyno software, and see what it makes.
Honestly, if it runs good, shows good/consistent boost, your AFR is in the correct range, I wouldn't worry about it. Drive and enjoy. Get it to the drag strip on some good tires and look at the trap speed... That's what tells you how fast your car is, not the dyno.
so they may be pretty strict now. I will report how car does when pushed on a hot day but felt good today!Thanks for your insight I really appreciate it
Adam
Adam
