Frustrated, Looking to get well into 600hp
Veteran
Hey, I have a97 A4 with A & A V-3 Si trim, diamond forged pistons, cincy speeds boost cam package, LS7 lifters, Trunion upgrade, LS2 connecting rods, perfoma trans level 3 A4 trans, Edge TQ converter 2800 to 3200 stall, using the 3.6 pulley, produced 549 rwhp / 471 tq with 11.4 psi best run with belt slip.
I have now upgraded to a 3.4" from the 3.6" pulley and added meth to it. Just wondering what to expect, I was running lean at around 530 hp 9.8 psi with no belt slip, so they had to stop tuning, they are adding a JMS voltage booster for the fuel tomorrow to make up for the lack of fuel. Just wondering what kind of numbers to expect if anyone else was running something similar.
Veteran
I would be good with that. Hopefully the JMS voltage booster will solve the lean problem, cancelled the dyno tonight on me, hopefully be able to get in tomorrow night. Im trying to get to Kil Kare for one more run on the new set up and Mickey ET's, it is going to drive me nuts to I have to wait until spring to find out what it will run!
