Hey guys looking for some advice on which kit to go for. Will be purchasing a kit soon to do at most 100shot and always thought the best option for such small shot is a dry kit. Talked to a few vendors (which btw were very helpfull) but i kept getting different inputs, some said wet kit is the best some said for 100shot just do a dry shot and call it a day. I know the best option would be a wet plate but i just cant justify spending ~$1500 for just 100shot. Will eventually be getting a SC kit but for now a 100shot dry kit i thiught should be sufficient enough.
What do you guys think, should i go for the dry kit or wet kit?
to save some money you can do a nozzle style wet kit and not a plate. You will also have to see what your fuel system will support. Without injectors and maybe a fuel pump you may not be able to fuel a dry shot.
I heard stock injectors and stock fuel pump can support up to 100 shot no problem. A lot people say no need to tune either but i will still tune it even for 100 shot.
Yes your good with stock injectors and fuel pump for a 100 wet shot.
Let me know if I can help you out with anything. We have kits in all price ranges.
