Exhaust issues....separating
Old Nov 7, 2015 | 10:03 PM
Forcedvert's Avatar
Forcedvert
Default Exhaust issues....separating
Three times my exhaust has come apart? I already had it back to the shop this week and it came apart again! I have lg headers, gutted cats, x pipe and factory ti cat back, I think this time it's at the gutted cats. Is this a common problem with sc cars? Is my shop doing something wrong? Any suggestions are welcome, special clamps needed?
Old Nov 7, 2015 | 10:41 PM
StingrayRebel's Avatar
StingrayRebel
I have superpros on my car and never had any problems like that... the worst part about them is the crappy clamps they provide... I didn't even bother trying to use them and immediately tossed them and they were replaced with these, http://www.jegs.com/i/Dynomax/289/33272/10002/-1 ... you should need 6 total to do the system all the way to the axle back... if your axle back has clamps similar to the ones supplied with the lg headers then you might consider replacing those as well with the appropriate size
Old Nov 7, 2015 | 11:18 PM
SBCGENII's Avatar
SBCGENII
Impact wrench.
Old Nov 8, 2015 | 01:49 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Tack weld. Will never come apart and takes a second to cut off when necessary.
Old Nov 8, 2015 | 02:01 PM
Forcedvert's Avatar
Forcedvert
Do you do this? Got pics?
Old Nov 8, 2015 | 03:04 PM
a/c man's Avatar
a/c man
mine are completely welded no reason to ever take them apart!
Old Nov 8, 2015 | 03:12 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Never really took a pic of that specifically. You can sort of make it out in this one.
The over the axle part was slightly separating from the xpipe. One very small tack on each pipe and I never had this issue again. They have been on and off several times. Takes a second to cut it off, and to re tack it after.
Old Nov 8, 2015 | 03:51 PM
Forcedvert's Avatar
Forcedvert
So one spot under each bracket?
Old Nov 8, 2015 | 03:56 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Yeah. One tack anywhere that gets the two pieces. The clamp should still be going most of the work. The weld just makes it impossible to separate by itself.
Old Nov 8, 2015 | 06:00 PM
Forcedvert's Avatar
Forcedvert
Yours comes apart where? Axel and headers? Because mine came apart at the headers once also
Old Nov 8, 2015 | 06:05 PM
a/c man's Avatar
a/c man
Mine never came apart just always had ex. leaks! so now the mid pipe is one piece. You have to really put the mid pipe on the headers as far as it can go and tighten the snot out of it
Old Nov 8, 2015 | 06:11 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Check your local Napa store for the EZ Seal brand. I've used those exclusively for years and never had issues. They usually run around $10-12 depending on area and store. Same thing as above essentially just a locally available option.
Old Nov 8, 2015 | 08:21 PM
SBCGENII's Avatar
SBCGENII
You might have a fuel leak.
Old Nov 8, 2015 | 08:24 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Just a small one.
To Exhaust issues....separating
