0-90 ohm gm fuel level sending unit ??
put a fuelcell in my 02 c5z ,came with a 0-90 ohm fuel level sending unit ,anyway to get that to work with the factory dash gas gauge?
Depending on style of sender you want, you can get custom made with any resistance you want.
Certainly in UK/Europe, dip tube style are more common for aftermarket race tanks, I had Fozmula make me a custom sender, wasnt too expensive either.
http://www.fozmula.com/products/fuel...-switches.html
http://technisolltd.co.uk/collection...tangular-tanks
Or if you want to use the sender you have, and know what you need it to read.
https://www.spiyda.com/magento/index...izard-mk2.html
lsxvette (11-09-2015)
Could be either a dip tube or lever arm, but it looks like a typical VDO style dip tube sender.
Either of the two companies above can make you a sender with whatever resistance range you want
lsxvette (11-10-2015)
Supporting Vendor
There are places in the tune where you can change calibration if needed. You should be able to eliminate the second tank in the tune too.
One place to look is in the "system" tab, IIRC.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
lsxvette (11-12-2015)
