Plan for replacement after ls1 lets go
Old Dec 6, 2015 | 03:49 PM
Travis_C's Avatar
Travis_C
Default Plan for replacement after ls1 lets go
Currently running stock bottom ls1 with ported heads, meth, and p1sc
Eventually I know it will let go.
I'm thinking of going with a Thompson forged ls3 shortblock and running my 241 heads. I could order dished Pistons to reduce compression.
Would like to skip having to buy new heads, intake and injectors if possible.
I believe all brackets including A&A procharger bracket should bolt up
Thoughts on this combo? And anything else I will need?
Old Dec 6, 2015 | 08:27 PM
Almost_There_1's Avatar
Almost_There_1
Are you on stock injectors?
Old Dec 6, 2015 | 09:17 PM
Travis_C's Avatar
Travis_C
No I think they are 60lb.
Monster stage 3 clutch.
Old Dec 7, 2015 | 12:14 AM
reactor2's Avatar
reactor2
Have you made any plans if it does NOT let go?
Seriously, these motors aren't as fragile as some would have you believe. Run lean, too much timing and you're looking at a paper weight...been there, done that, still going strong year after year!
Old Dec 7, 2015 | 05:26 AM
romandian's Avatar
romandian
how much boost do you see?
Old Dec 7, 2015 | 08:11 AM
Travis_C's Avatar
Travis_C
8lbs.
Show me speed tuned it when previous owner had it. They said its tuned on edge.
Thinking of upgrading to D1sc and turning up the boost.
Old Dec 7, 2015 | 10:30 AM
robert miller's Avatar
robert miller
Originally Posted by Travis_C
8lbs.
As long as your tune is good you should be good in the car for some time. But that ls3 is a good one to go with and the 241 ported heads on it & at that time a new set of V/spring in them go for a number of years in her..
Old Dec 7, 2015 | 10:44 AM
romandian's Avatar
romandian
i have a stock ls1 on 14 lbs of boost. im driving it and it still lives.
Old Dec 7, 2015 | 12:54 PM
Travis_C's Avatar
Travis_C
If I change to a D1SC and keep my current 3.4 pulley it say I should be around the same amount of boost.
How much HP are you getting out of 14lbs?
Old Dec 7, 2015 | 01:14 PM
robert miller
14 lbs on stock bottom end if one little problem goes wrong you will be getting that new motor sooner than later. Just go with what you have at a save 8 lbs and just have fun in the car until you go with the new motor..Robert
Old Dec 7, 2015 | 01:34 PM
StingrayRebel's Avatar
StingrayRebel
I think you would be seeing more than 14psi on a d1 with a 3.4 pulley... with a 4.125 I see 16psi on my d1 with headers, cam, od balancer, stock block/heads
Old Dec 7, 2015 | 01:43 PM
Travis_C's Avatar
Travis_C
http://zero2sixtymotorsports.com/pro...st-calculator/
Check this page out. The under drive pulley is where you are getting more boost. Plug your numbers in and see how close it is.
Old Dec 7, 2015 | 01:54 PM
StingrayRebel
that calculator is off, it's telling me I would be a little over 17psi with a 3.4 pulley... elevation will also have an effect and I'm aware that I'm gaining a bit of boost with the od balancer but maybe 2psi at most, so take that out of the equation and I'd be seeing around 14psi with a stock balancer... with the stock balancer and 4.38 I saw 12psi... if I ran a 3.4 on my setup I'd probably be around 22-23psi and that calculator is saying a little over 17... there are many variables that come into play though so once you have a baseline on your setup you can guesstimate where you will end up
Old Dec 7, 2015 | 05:08 PM
Milan's Avatar
Milan
forged pistons and rods aren't really much better off against a poor tune
Old Dec 7, 2015 | 05:31 PM
Travis_C's Avatar
Travis_C
How much HP are you making?
Old Dec 7, 2015 | 08:18 PM
PEETYZ's Avatar
PEETYZ
Use this calculator http://www.928motorsports.com/servic...tingpulley.php
Old Dec 7, 2015 | 08:57 PM
StingrayRebel
haven't had it on a dyno since adding the od balancer, 4.125 pulley, fuel system, etc, but I would guess around 825-850rwhp... hopefully
To Plan for replacement after ls1 lets go
