I have a 98 coupe, with a p1sc, dual front mount intercoolers. I have long tubes, full exhaust, ls6 intake.. On my 4.25 pulley I was right around 5psi. That was with a 92.5 belt, 6rib.. I swapped on a 3.85 pulley today, and used a 91.0 6rib belt.. At wot, I am right around 4.5 psi now.
I don't think I have belt slip, as there is no noise, and the boost stays constant, but I am not 100% sure.
Tomorrow I am going to check all my piping fittings, air filter inlet, and bypass valve. Any other suggestions would be very helpful. I was hoping to see 7-8psi with this smaller pulley.
Not really. Was thinking the same thing about the gauge. At idle it reads 20psi vac, and at wot it's about 4.5psi of boost. The blower is a little louder for sure now.
I have read that people take off the air filter inlet and run it to see if there is a restriction in that. Also I saw that people plug the bypass valve and run it without it and see if that is the issue. My question is if I plug the bypass valve, is that bad to have all the boost on the tb at all times, when my car wasn't tuned with that??
anks for the suggestions guy. Think I found the issue. My bottom bracket bolt was loose, causing some belt slip I believe. Haven't driven it yet to confirm. I checked the bypass valve and by revving it up, the valve seals at 0 on the boost gauge.
