Does Methanol go bad?
Old Feb 14, 2016 | 09:16 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default Does Methanol go bad?
I've had methanol in a plastic 5 gallon gas container going on 3 years. I've been using it, but still have plenty left. It just dawned on me... does it ever go bad?
Old Feb 14, 2016 | 11:12 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
After a 30 second Google search methanol.org says, it has an indefinite shelf life. With that said, if it did have a shelf life; I don't know if you will find anyone on here who's ever had any long enough to find out.
Old Feb 14, 2016 | 12:30 PM
js23881's Avatar
js23881
I asked my supplier that very question late last year. They told me it would last indefinitly as long as it was kept in an enclosed container OFF the cold floor. They said a plastic (never use aluminum or steel as it corrodes with meth) container resting on a cold floor has a habit of allowing/forming condensation to get into it somehow.....FYI.
I have had 5 year old 2 gallon jug of meth work fine. Kept it stored on top of wood shelf off floor.
Old Feb 14, 2016 | 01:45 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Good advice
Old Feb 14, 2016 | 03:43 PM
StingrayRebel's Avatar
StingrayRebel
most of us use meth as an alternative fuel and not primary so if any condensation were to build up in whatever container it was being kept in would it really hurt it to a noticeable point?... many of us also run 100% meth so I'm just curious since some run a 50/50 mix which seems like it would be far more diluted than a little condensation
Old Feb 15, 2016 | 08:11 AM
Shirl's Avatar
Shirl
Thank you so much for all of the info everyone. I do keep the plastic fuel container of meth in the garage on a concrete floor though. Maybe I can move it someplace else or inside. Will probably get a refill of it this year anyway, I guess.. Thanks again!
Old Feb 15, 2016 | 10:46 AM
PEETYZ's Avatar
PEETYZ
If you are worried about it its cheap enough to get from local racing fuel place at the pump. I think it was $2.19 a gallon for 100% meth at place near my house. You can mix the old up with distilled water to a 70% water 30% meth up to 50/50 mix for your own home made washer and de icer fluid for your daily drivers..
Old Feb 15, 2016 | 08:57 PM
95wht6spd's Avatar
95wht6spd
No, but after a couple months it doesn't taste as good.
Old Feb 16, 2016 | 02:53 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Methanol is like brake fluid, in that it's hygroscopic or has the ability to attract water from its environment. The only way you're going to get any significant amount of water in it would be to continuously open the container on humid days.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Feb 20, 2016 | 12:18 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
This, and in speaking to VP reps it maintains purity after one year of being opened then after that the amount of degradation is negligible
To Does Methanol go bad?
