Nitrous kit advice
Old Mar 6, 2016 | 01:03 AM
teach79's Avatar
teach79
Default Nitrous kit advice
Hi all I have built ls2 406 in a c5z and I wanna run a a 100 shot with a progressive controller because I wanna be as easy on the motor as possible . Looking for a complate kit with plate ,bottle warmer and controller , what would you use ? Which kit is the best ? I plan on pulling 4 degrees of timing . ANY issues that I am not thinking of ?
Old Mar 6, 2016 | 05:58 AM
mattressbouncer's Avatar
mattressbouncer
Give the guys at Nitrous Express or Nitrous Outlet a call. Can't go wrong with either. Go with a plate kit rather than a nozzle. Also get a couple sets of BR7ef spark plugs.
How built is your built engine. You'll be wanting to blow past a 100 shot almost immediately. 150-175 can be run on a stock engine easy, so you may want to plan for the future and get a kit that can go up to a 250 shot.
Old Mar 6, 2016 | 02:38 PM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
I can set you up with everything you need.
What intake manifold are you running?
Old Mar 6, 2016 | 03:10 PM
teach79's Avatar
teach79
Default 92 mm fast
This is my list I am pricing out . 10lb bottle wet kit t- body plate , purge set up , remote opener , warmer and nitrous controller . I want the options of adjustability with this kit . I have comp u star internals 92 mm fast 215 afrs and making 550 hp at the wheels now . I just want a little more if needed. I want to be as safe as possible I will be re tuning the car to pull 3 to 4 degrees w nitrous . Thanks for the help
Old Mar 6, 2016 | 04:45 PM
Supporting Vendor
Plate kit
http://nitrousexpress.com/20934-10-l...e.html#Options
Purge
http://nitrousexpress.com/15601-nitr...-manifold.html
Remote Opener
http://nitrousexpress.com/11107-auto...le-opener.html
Heater w/gauge
http://nitrousexpress.com/15937-10-1...ous-gauge.html
Max 4 controller
http://nitrousexpress.com/15957-maxi...ontroller.html
As always PM me for the forum discount price.
Old Mar 9, 2016 | 12:09 PM
GS_DAN's Avatar
GS_DAN
I would not do a progressive on a 100 shot.. 150 and over maybe but the 100 shot is not going to feel like a whole whole lot. Also, you have a forged motor let that thing eat!
Old Mar 9, 2016 | 12:11 PM
GS_DAN's Avatar
GS_DAN
Also might want to think about adding a second bottle/bracket if you plan on using it very often. A 10lb bottle is gone before you know it.
what are you using for fuel pump?
Old Mar 9, 2016 | 02:05 PM
dankhts's Avatar
dankhts
went with the Nitrous Express 92 MM plate kit, good service and advice, no regrets ....
Old Mar 10, 2016 | 12:47 AM
teach79's Avatar
teach79
Thanks for the heads up .
Old Mar 10, 2016 | 02:27 PM
NitrousOutlet's Avatar
0NitrousOutlet
Former Vendor
Which intake and throttle body combo are you running? Also, are you still on stock fuel rails or aftermarket?
Old Mar 12, 2016 | 06:58 PM
teach79's Avatar
teach79
Default 92
92 mm fast ,tpis 90 mm t body, can't remember the fuel rails but yes aftermarket rails .
Old Mar 14, 2016 | 12:09 PM
0NitrousOutlet
Former Vendor
Alright, let me work it up for you. As soon as I get it finished I'll send you a PM-
Old Mar 14, 2016 | 01:14 PM
teach79's Avatar
teach79
Default Nos
You guys sell those 1 gallon stand alone fuel setups for a 02 z ? If so how much
Old Mar 14, 2016 | 01:48 PM
FourG63 97GST's Avatar
FourG63 97GST
agreed, probably won't even have to pull timing
Old Mar 24, 2016 | 02:25 PM
0NitrousOutlet
Former Vendor
Here's a link to the aluminum C5 Dedicated Fuel System. They are a bolt-on fueling solution for your nitrous system, and are very user friendly. The dedicated fuel systems include everything you need to get them going besides a 6AN fitting for your fuel solenoid inlet. The systems are 899.99+shipping.
http://www.nitrousoutlet.com/fuel-de...el-system.html
To Nitrous kit advice
