TH400 install thread.
Mar 6, 2016 | 11:52 AM
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Some in here have asked about installing a TH400 in a C5.
Since it's more of a tech subject than an FI thing, I made a thread in the tech section.
https://www.corvetteforum.com/forums...into-a-c5.html
Mar 10, 2016 | 01:23 AM
Mar 10, 2016 | 09:49 AM
Cruise-In III Veteran
Cruise-In IV Veteran
Mar 12, 2016 | 10:20 AM
Thanks guys. It was a fun project. Took a bit to get used to running down the track though. I had forgotten I needed to shift...
Shift light came on and I was, "oh sh!ft! lol.
Mar 14, 2016 | 11:59 AM
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Pete meant to ask you,Did you have problems with the 4L60E? Is that why you went to a 400?
Mar 14, 2016 | 01:12 PM
Paul, no problems with the 4l60, just had an opportunity to make a swap with a friend and knew I was going to need the set up eventually.
I broke the C5 rear last year at Atco, so that's what prompted the swap to the C6 rear.
I hope to be at the track in early April.
Mar 28, 2016 | 08:38 PM
