oil temp sensor wire diagram
Old Mar 10, 2016 | 01:17 PM
StealthFRC's Avatar
StealthFRC
Default oil temp sensor wire diagram
anyone have a diagram as to where these wires go? mine are broken near the harness and i cant get access to strip them back and solder some extensions on, im sick of having issues with these wires since the turbos are basically right next to this harness and ive had nothing but issues with these 2 wires.... id like to just run all new wires from wherever then come from if possible and reroute them so i never have to worry about the little bastards again...
do they go to the pcm?
if so witch pins? is it just straight wire from the plug to the sensor? or are there resistors or something in the harness attached to the wires?
