Remind me what was done and changed? Was the engine out?
Nothing changed. Engine was out for heads to get checked out. Only change was a new clutch and transmission.
Tach is not moving while cranking. I've never paid attention to it before so I am not sure if it should be moving. I'll have to hook up my HP tuners to verify tach.
These are good for checking spark and I think you might be able to hear it if you are by yourself. Probably just something you missed when swapping heads like a ground that was already mentioned. http://m.autozone.com/test-scan-and-...ter/10257_0_0/
Checked spark, all good. I "think" it's a problem with the injector plugs, I'm fairly certain I had them plug in upside down if that makes sense. The plug on them I modified AKA cut the tabs off so I wouldn't have to install new ends. I'll check my theory tomorrow since I had to pull a fuel rail off that was leaking.
MAP sensor reading correctly? Not to shoot your injector idea down, because its totally possible since this is internet diagnosis and all, but you did say you smell fuel when cranking not that its definitive. Sure you have the cam and MAP sensors plugged in to the right sensor. Seen that happen a few times especially with boosted cars. So just check it on HPT and see if its reading right. Especially if you've done a swap to a front cover cam signal etc... Depending on the extension harness used they can be plugged in backwards too. GL! I'll bet its something super simple though.
I'm following this thread. I have similar but different no start issue. In my case I know I have spark and I know my grounds are good, but with new pump and wiring I do not have fuel PSI. New pump arrives tomorrow. New left side tank (stripped threads on fuel sender cover bolt holes) arrives whenever it gets here from Vettenuts. Hopefully THEN it will be all good.
GL with yours! Definitely check all your grounds. Back of the head. Block on passenger side under headers. And both forward locations in engine bay (aft of headlights on top of frame)
I logged the map through hp tuners. Fuel smell ended up being from the fuel rail leaking where a fitting was welded on.
All sensors are stock and stock location as they came from GM. None of that changed from the original build in late 2011-12.
Ok so saying you logged them I'm guessing that means they were reading correctly. Hmm Well I know you said you checked the fuses, but Bill recently had his inj fuses popping under high boost pulls. So if all of them are not firing I'm saying stay on that check the those fuses specifically, and the ground on the back of the head that supply's the ground for them. Its easy to miss one being its behind the head. If none of that pans out your going to have to start checking continuity from the injector to the PCM.
All grounds have been triple checked. All fuses have been checked numerous times Nd even replaced just to be sure.
The one behind the head is stupid easy to get to since I have the cowl off and the big *** hole I cut in it back when I built this engine to clear the fuel rail and feed line, haha.
The P 1518 code is leading me in a new direction. Talked to Brett (blownblue) earlier and he thinks I left a wire from the S post on the alternator wiring that is supposed to go to the starter. We went over how many and what wires I have installed there and think we may have found the issue. That code also shows its face when there is a tac module problem, hence the wire he told me about. The car has thrown the reduced engine power on the DIC, but I paid it no mind.
