Going FI Finally! Need some pointers...
I think I understand how to do the compression test but Iam a little unsure about finding TDC when performing the leak down...can someone who has done this give some pointers or if your close by to middle TN and want to aid and assist by all means let me know! I'll buy the beer!
This is so far everything I know: Please if you can answer the few questions I have and provide any tips I would kindly appreciate it.
https://www.corvetteforum.com/forums...-check-me.html
Remove flywheel inspection plate and turn the flywheel by hand (remove spark plugs first). Have a buddy let you know when you're at TDC by using a pick in the spark plug hole or bore scope.
I have used a compression tester hose, removed the Schrader valve, taped a balloon on the end and bumped the starter to right when the balloon stops inflating. It make take a few turns, but you'll get it.
No that's why it's an inspection plate.
You have to pull the steering rack to gain access to the crank bolt. It's a huge PITA. How else are you going to turn the engine over other than how I described?
If you click on the link I provided...guy on there said simply put in 20 psi and feel for where TBC is. I also have read to put a screwdriver or similar too to feel when TDC is reached. All this while just cranking it over 4-6 seconds. Iam no mechanic nor claim to be one, just going by posts and comments left on the forum.
