Low end sputtering
Old Jun 12, 2016 | 12:14 PM
EnVmYc5's Avatar
EnVmYc5
Default Low end sputtering
01Z w/novi 1500
Car was driven around the block earlier in the day just moving the car and it was fine
As day went on and temp went up
The same ride w/ drive load about 2000 rpms it would start sputtering like a misfire.
If u push clutch in and rev the car no issue.
No codes!
Any suggestions?
Everything looks good idles fine thinking car needs to adapt to the extreme heat today
Thanks,
Nick
Old Jun 12, 2016 | 12:17 PM
EnVmYc5's Avatar
EnVmYc5
Default Forgot to subscribe
Forgot to set up for notifications
Old Jun 13, 2016 | 08:39 AM
skull's Avatar
skull
pull and check plugs for condition. make sure your gaps are good.
Old Jun 13, 2016 | 03:31 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I would go to the wires first, then onto plugs. Most likely an easy fix IMO.
Old Jun 13, 2016 | 05:05 PM
EnVmYc5's Avatar
EnVmYc5
One of the wires on the driver side closest to egr tube was touching
no burn thru but took it off and repositioned it. Took it for a ride no issues!
To Low end sputtering
