Ecs Fuel system leak
Old Jul 2, 2016 | 01:06 PM
97 SC Cobra's Avatar
97 SC Cobra
Default Ecs Fuel system leak
Hey guys, I have an ecs fuel system on my c5 and I have a slow seep at the bulkhead. Basically every 15 min I get a big drop hanging from it at the bottom where the o ring goes into a D shape. The screws are small and I've slowly went around and tightened them a couple times but she's seeping. Stinks in the garage and I don't feel it's safe so how far can I go with tightening these things. I know I'm in deep if I snap one off. There's over half a tank of fuel in the car.
Thanks for any input.
Old Jul 2, 2016 | 02:05 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Drain the fuel by removing the fuel line at the rail with an added section of hose to it so you can put that end into a gas can and jumper the FP relay with power until empty.
Then remove the block and check for dirt, pinched o-ring etc on the housing. If a new o-ring needed let us know and we can get one right out to you.
Good luck with the fix.
Old Jul 2, 2016 | 02:22 PM
97 SC Cobra
Thanks doug I'll let you know how I make out.
To Ecs Fuel system leak
