Remote bottle opener doesnt work. Need Help
Old Sep 10, 2002 | 02:13 PM
whip383's Avatar
whip383
Default Remote bottle opener doesnt work. Need Help
Well, im getting pretty tired of the remote bottle opener. My first problem with it is that i have to take it off everytime I fill the bottle. So the last time the nut finally went bad on the clamp from the bottle opener. I call NE they send me a new one, for $26. Can you believe that? Then I put it on, the bottle still wont open and the new clamp's nut is now already sorta stripped, after the first use. So I tried everything, but it wont open my bottle. Any suggestions? It seems like it too hard or too much torque is needed to open the bottle. Maybe WD-40, what do u think, have any of u had this problem?
thanks,
Chan
Old Sep 10, 2002 | 02:35 PM
shftn6's Avatar
shftn6
Default Re: Remote bottle opener doesnt work. Need Help (whip383)
The only problem I have with mine is if I hold the open button too long I can't get it back closed. Also after I fill my bottle I have to let the opener close it once installed or it will be too tight for the remote opener to open.
Old Sep 10, 2002 | 06:03 PM
whip383's Avatar
whip383
Default Re: Remote bottle opener doesnt work. Need Help (shftn6)
does that mean u leave it open with the bottle full? cause then i would have to put the remote opener on, tighten it down with the clamp, then try to close it, how much n2o do u lose?
thanks
chan
Old Sep 10, 2002 | 06:45 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Big Chan ,
there's a very simple soultion..Get an ATI SC installed and you won't have to mess with the bottle any more ;)
:cheers:
Jeff
Old Sep 10, 2002 | 10:30 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Remote bottle opener doesnt work. Need Help (BLUTHUNDER)
why do you take the opener off the bottles? I just use a 12v drill battery (craftsman) to open and close the bottle. Put some butt connectors on the openers red & black wire. Make sure the male end is on the opener when you remove it, then touch the wires to the battery and it will open the bottle opener. To Close reverse polarity.
Old Sep 11, 2002 | 04:32 PM
whip383's Avatar
whip383
Default Re: Remote bottle opener doesnt work. Need Help (ICULUKN-C5)
Jeff, when im big money like u, then ill do that :)
I will do the 12v battery thingie, but i cant get it to work now, thats my problem, the bottle opener doesnt open the bottle. Ive even left the bottle slightly open and then tried to put the opener on, it wont open it any further?
chan
Old Sep 11, 2002 | 06:27 PM
compuvette's Avatar
compuvette
Man, I was thinking of picking one of those up, too! I will have to think that over.
Old Sep 12, 2002 | 01:14 AM
BLUTHUNDER's Avatar
BLUTHUNDER
chan
Chan my good man ,
it's all about priorities..I'm actually getting used to sleeping in my cardboard box under the overpass :yesnod:
:cheers:
Jeff
[Modified by BLUTHUNDER, 5:15 AM 9/12/2002]
Old Sep 12, 2002 | 12:36 PM
whip383's Avatar
whip383
yea yea, ill be down there real soon, ill see ur cardboard box. i think first or second week of oct. i hope all is well. cant wait to take a ride in the rocket.
Chan :cheers:
Old Sep 17, 2002 | 02:27 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
You need to take the bottle opener apart and tighten the clutch. Not hard at all to do. Over time the clutch needs to be adjusted...
Old Sep 17, 2002 | 04:23 AM
tito's Avatar
tito
Default Re: Remote bottle opener doesnt work. Need Help (C5-VERT)
i simply gave up with my opener.. now.. i just get my azz up and open it. :lol:
Old Sep 18, 2002 | 12:51 AM
nowalks2000's Avatar
nowalks2000
Default Re: Remote bottle opener doesnt work. Need Help (tito)
WHY IS EVERYONE USING Z-06 SLAVES W/ AFTERMARKET CLUTCHES INSTEAD OF SLAVES MADE BY CLUTCH MANUFACTUR?
:sleep:
Old Sep 18, 2002 | 12:53 AM
nowalks2000
WHY A Z-06 SLAVE INSTEAD OF THE ONE THAT COMES FROM SPECK/STAR
Old Sep 18, 2002 | 01:33 AM
C5-VERT's Avatar
C5-VERT
Default Re: Remote bottle opener doesnt work. Need Help (nowalks2000)
Weird...what the hell does this have to do w/ nitrous bottle openers?
OK, lets see, after pulling the tranny 3 times in the last two weeks I can tell you. The z06 slave works!
After talking w/ spec on numerous occasions they never mentioned anything about a slave they make for the C5. :rolleyes:
[Modified by C5-VERT, 12:34 AM 9/18/2002]
Old Sep 18, 2002 | 02:39 AM
whip383's Avatar
whip383
is it pretty easy to open????? instructions?
thanks,
chan :cheers:
Old Sep 18, 2002 | 02:58 AM
C5-VERT's Avatar
C5-VERT
Well its been a while but it is very easy to do.
You remove the four screws from the top. Then there should be a nut that you can tighten. I think you have to hold the other side(that actually turns the bottle) while you tighten the nut. I can take my extra bottle opener apart tommorrow to check for you if you cannot get it.
Old Sep 18, 2002 | 01:34 PM
whip383's Avatar
whip383
oh u dont have to open it up, ill try this weekend, but thanks for the offer. if i cant get it to work, i ll shoot u an IM.
thanks,
Chan
Old Sep 18, 2002 | 10:25 PM
nowalks2000
THIS HAS NOTHING TO DO WITH BOTTLE OPENERS.
I MOVED THIS TOPIC OVER TO C5 TECH/PERFORMANCE
I CALLED SPEC TODAY THE REASON THEY NEVER MENTIONED THE BILLET ADJUSTABLE PRESSURE STATE OF THE ART ONE OF A KIND MASTER AND SLAVE IS BECAUSE THEY ARE ON A MAJOR BACK ORDER AND THEY SEEM TO BE PUSHING THE Z-06 ONES. I HAVE THE BILLET SPEC/STAR SYSTEM IN MY CAR AS OF TODAY. I WILL LET YOU KNOW HOW IT WORKS AFTER THE 400 MILE BREAK IN. 24 HOURS NO SLEEP LOTS OF NO DOZE [IMG][/IMG] :sleep: :sleep:
Old Sep 19, 2002 | 01:12 AM
C5-VERT's Avatar
C5-VERT
You are talking about the SLAVE right? Not the master. I have an mcloed adj. master now. Let me know how it turns out. Mine is still flawless, knock on wood!
To Remote bottle opener doesnt work. Need Help
