T56 experts
Old Jul 30, 2016 | 07:58 PM
Hectorls1's Avatar
Hectorls1
Default T56 experts
Who makes a T56 rebuild kit? The gearbox has them in back order. Is the T56 in Camaro/Firebird/Viper the same?http://www.hawksmotorsports.com/t56-...me-parts-only/
Old Jul 30, 2016 | 09:14 PM
HardcoreABN's Avatar
HardcoreABN
no, they are not the same. The camaro/firebird/viper use a double/single cone synchro while the Corvette uses a triple/double cone synchro.
There have been supply problems over the last few years for the triple/double cone synchro blocking rings and friction cones.
Old Jul 30, 2016 | 09:31 PM
Hectorls1's Avatar
Hectorls1
Seems to me that the kit in then link above should work fine then.
Old Jul 30, 2016 | 09:54 PM
HardcoreABN
there is no way in hell that will work. For starters, that is a double/single synchro transmission. Second, that is the wrong mainshaft since the transmission bolts TO the differential.
A Camaro/Firebird/Viper kit WILL NOT work. The parts will not physically fit. The gears and such are all different in a triple/double synchro trans than they are in a double/single synchro trans.
Old Jul 30, 2016 | 10:11 PM
Hectorls1's Avatar
Hectorls1
Good to know, thank you. The gearbox kit is in back order.
Old Aug 1, 2016 | 09:03 AM
PEETYZ's Avatar
PEETYZ
RPM and Tick should be able to help you out with parts
Old Aug 1, 2016 | 02:38 PM
Matt@Tick's Avatar
0Matt@Tick
Former Vendor
Give us a call. 336-719-0599
To T56 experts
