NITROUS QUESTION
Old Sep 13, 2002 | 08:45 PM
YLLW02ZO6's Avatar
YLLW02ZO6
Default NITROUS QUESTION
CAN A ZO6 HANDLE A 100 SHOT OF NOS? HOW MANY OF YOU HAVE BLOWN THE MOTOR RUNNING NOS. I DO PLAN ON BUYING ALL THE SAFETY THINGS AVAILABLE FOR THE SYSTEM. AND IF THE MOTOR DOES BLOW CAN YOU REMOVE NOS SO THAT YOU CANT TELL IT WAS THERE.
THANKS FOR THE FEEDBACK
Old Sep 14, 2002 | 12:48 AM
bruce1's Avatar
bruce1
Default Re: NITROUS QUESTION (YLLW02ZO6)
Yes, 100 shot will work.... But still you must do some maintaince on the ayaten, and try to keep it as safe as possible....I have never blown antthing on mine.
I must have 100 + runs on the LS1 now.
Old Sep 14, 2002 | 12:51 AM
bruce1's Avatar
bruce1
I do not see anything that would stop you from removing it, if you wanted to that is.... :D
Good luck.......
ps
I run the NX express set up.
[Modified by bruce1, 8:52 PM 9/13/2002]
Old Sep 16, 2002 | 12:29 PM
compuvette's Avatar
compuvette
NX states that 20HP per cyl. is the safe limit, so on a V8 with stock pistons you should be able to spray 160HP.
To NITROUS QUESTION
