C5 nitrous nos mini tps question
Old 10-16-2016, 03:38 PM
lpina650
lpina650's Avatar
Default C5 nitrous nos mini tps question
Hello,
I've always had f body's in the past with a nos mini nitrous controller. Is it the same on a c5 to lock in your tps voltage to the nos mini controller? I've always put the key in the accessory mode with the engine off and went full throttle on the gas pedal and my tps voltage would show on the nos mini controller. I cannot get a voltage this way in my c5.
Is this the correct way In a c5
Old 10-16-2016, 05:28 PM
SPEED750
SPEED750's Avatar
Well the C5 is "fly by wire" throttle and I don't believe the F bodies are. This might be the problem. Have you tried it with the key in the run position ?
Old 10-16-2016, 08:02 PM
Scotty_Z06
Scotty_Z06's Avatar
just pm'd you but with it in the accessory mode, pop off your intake and manually open the tb with the controller set on step 9 i believe. should register at roughly 4.7v assuming you're tapped in to the correct wire.
To C5 nitrous nos mini tps question
Quick Reply: C5 nitrous nos mini tps question
