Heads Cam NITROUS Dyno Sheet!!!==>
Old Sep 17, 2002 | 03:56 PM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Default Heads Cam NITROUS Dyno Sheet!!
This is my heads cam setup with 22 degrees of tuning & a really rich setup :) :) Should be good for alot more than the 150 jets that we ran on this pull :) Hope to run 200 shot asap ;) NA sheet is on bottom :)
NA DYNO
ENJOY :)
Jason
99 FRC
JPE Racing Stage 2+
Heads & Cam Package
FU-2 Cam
TPIS Headers
Borla
10.80@130mph @5000ft
Running The 100 Shot!
[Modified by Jason 98 TA, 1:57 PM 9/17/2002]
Old Sep 17, 2002 | 06:32 PM
bruce1's Avatar
bruce1
Default Re: Heads Cam NITROUS Dyno Sheet!! (Jason 98 TA)
Looks good Jason............
Come down to Carlsbad, so we can line up together.
:D
I would be a gooooooood match indeed.
Old Sep 18, 2002 | 01:37 PM
Corvette4ever's Avatar
Corvette4ever
WOW! The hp curve in the nitrous dyno is really flat :eek:
What nitrous brand is this?
Old Sep 18, 2002 | 08:32 PM
akw408's Avatar
akw408
Whoa, awesome #s. I can't believe you haven't fried your clutch yet. If that is a 150shot, it must be TNT.
And are we looking at the same car? In one dyno sheet it looks like 448RWHP and the other is 415RWHP, NA. Or is the 415RWHP detuned to 22 degrees of timing and 11.6 AFR? What is your AF and max ignition timing normally at, in the 448RWHP?
Old Sep 18, 2002 | 11:58 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Great looking dyno's Jason! :)
440RWHP @ 30 degrees with 13.0:1 AFR
415RWHP @ 24 degress with < 12.0:1 AFR
590RWHP @ 24 degress with <11.0:1 AFR + TNT 150 shot (175rwhp gain)
The "nitrous tune" should be good to close to 700RWHP.
[Modified by Godspeed, 10:01 PM 9/18/2002]
Old Sep 19, 2002 | 12:16 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: Heads Cam NITROUS Dyno Sheet!! (Godspeed)
How do you switch between the NA tune and nitrous tune? Do you have two separate PCM's, and just swap them out?
-Tuan
Old Sep 20, 2002 | 10:28 AM
Jason 98 TA
http://www.racingflix.com/getvideo.asp?v=109
To Heads Cam NITROUS Dyno Sheet!!!==>
