evap boost leak
Old Nov 15, 2016 | 01:49 PM
luvTTwins's Avatar
luvTTwins
Default evap boost leak
I've got a 97 with a 76mm turbo. Its not spoiling as fast as I feel it should be. I've been chasing down leaks. During a boost leak test at 15psi I have quite a bit of air coming from the evap relay(i think) by the drivers side fuel rail. Is it possible to delete that and cap the line. What have you guys done?
Old Nov 15, 2016 | 04:03 PM
silver408z's Avatar
silver408z
Are you having blowbye of the rings?
Old Nov 15, 2016 | 08:05 PM
Turpid porpoise's Avatar
Turpid porpoise
I have my evap solenoid completely removed, plugged the manifold and had my tuner erase the codes. Works great
Old Nov 15, 2016 | 10:03 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Remove, cap, turn off code, problem gone
To evap boost leak
