Intermittant check engine flashing question
Old Sep 18, 2002 | 02:09 PM
dbvettez06's Avatar
dbvettez06
Default Intermittant check engine flashing question
When driving over 6000 usually in 3rd i get a flashing check engine light...It then goes away within a minute...Any ideas :confused:
Old Sep 18, 2002 | 02:26 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Intermittant check engine flashing question (dbvettez06)
Misfire detected. I would start by taking a close look at the plug wires (things may be moving quite a bit as you shift)
[Modified by QuickSilver2002, 6:37 PM 9/18/2002]
Old Sep 18, 2002 | 07:56 PM
Crushinator's Avatar
Crushinator
Default Re: Intermittant check engine flashing question (QuickSilver2002)
Either that or your plugs aren't gapped correctly. At that RPM, there's a good chance the spark is being blown out creating the misfire. They should be gapped at .035 and make sure they're not platinum. Those little pucks fall off making the gap much wider. That'll do it everytime.
Old Sep 18, 2002 | 09:37 PM
TJ_ZR-1's Avatar
TJ_ZR-1
I had the exact same problem. Turned out #7 wire had a hole near the plug..brand new Taylor thundervolts. Actually cost me 20 hp on the dyno. Never set a PCM code.
Toby
To Intermittant check engine flashing question
