E85
Old Dec 17, 2016 | 12:56 PM
TheBandit18's Avatar
TheBandit18
Default E85
I have a 99 frc putting UPP twin turbo kit with the 6182r turbos and there external fuel return style fuel system.
Just curious on what else I need to run e85. Stock engine(for now) 60lbs injectors.
Hoping to be around 600rwhp with stock engine.
Thanks!
Old Dec 17, 2016 | 02:00 PM
stevieturbo's Avatar
stevieturbo
At only 600hp, E85 probably isnt worth the expense or hassle.
Old Dec 17, 2016 | 02:16 PM
TheBandit18
My end goal is around 850rwhp. And instead of running meth now just go to e85
Old Dec 17, 2016 | 04:20 PM
FourG63 97GST's Avatar
FourG63 97GST
that's basically it. pump, injectors, filters, and tune. I did a homemade external setup, similar to the ECS, bosch 044, modified factory fuel rail, check valve on the external side.
I mainly ran it for safety while testing new setups. and it smells better , it burn more fuel, but mathematically cheaper/mile for me than running 93. it's only a hassle if you dont have a station nearby.
Old Dec 17, 2016 | 05:00 PM
Ronnie_W's Avatar
Ronnie_W
What about fuel lines if you have after market braided lines.
Old Dec 17, 2016 | 05:10 PM
stevieturbo
Teflon or suitable metal lines.
Braided means nothing as you can have teflon braided or rubber braided.
Old Dec 17, 2016 | 05:40 PM
TheBandit18
Ok sweet. I hearsld a few things about a flex fuel kit. Is thst just so you can run both e85 and pump gas?
Old Dec 18, 2016 | 03:54 PM
HardcoreABN's Avatar
HardcoreABN
I wouldn't use anything besides a quality PTFE line for fuel. My preference is Fragola. 100% Made in the USA - because that matters to me.
To E85
