Not sure to put it back on
I guess if the new engine you have now is fast enough for you, Retire the Nitrous. I don't know what to do. I didn't want to spend more money to change to an all N/A engine. Good Luck.
your new engine should hold the Juice without a problem.
I hope ARE does service you good now, Matt told me they would.
And the engine will be strong then.
You will have fun with it!!!!
No need to be gun shy....you know enough about Nitrous and you will see
lot´s of low tenths and high nines without a problem.
I have a good feeling, you´ll see I´m right.
Don´t get frustrated in your old days, buddy!!! :lol:
You know that you´re my idol, I learned such a lot from you about Nitrous use and hard launches..........................
You´re one of the fastest here on the forum.................
.........................and you will be in the future, too!!!!!!
This is to you my friend.
:smash: :cheers: :smash:
Michael
ICULUK-C5
Tom played a bit too much with the NOS on his stock engine....he did 225+ hp wet+dry shots.......that´s on or better let`s say above the limit of the stock engine.
I´m pretty sure the engine faílure he had with his new stroker will not happen again....ARE should take care of that.
I also play a lot with that Nitous stuff....no failure, yet (knock on wood), but it can happen everytime.
If you play with that hp....equal if turbo or Nitrous....something can break.
If you wanna stay save.....stay stock.
If you need the power (like I do)....then be prepared to invest some $.
We all have to pay to play.
Michael
[Modified by Austrian Vette, 7:02 PM 9/22/2002]
I would be devistated emotially & alittle financially if my brand new 02' short block ($5500.00) went south becuase of something stupid, like the fuel solenoid not opening, or a piece of something getting past the n2o filter
and screwing things up again.A good idea might be to save up for a blower. That'll be more consistent with less chance of a meltdown IMO.
:cheers:
and screwing things up again.Michael
(edit) Actually you would have quite a bit more than 520 as you have heads/cam and long tubes. Sorry the 520 number came from 2 bone stock ATI Z06's we completed.
[Modified by billreid1@***.net, 12:31 PM 9/22/2002]
in the summer time
http://www.ap-engineering.com/ls1_extras.html
